Air in Fuel Line/ Injector Rail
Old Sep 5, 2016 | 10:15 AM
mtnbkr909's Avatar
mtnbkr909
Swapped out fuel filters yesterday and got some air in the line (don't ask me how). Initially got a low fuel pressure alert and then a reduced engine power alert at which time check engine light came on. Resolved air leak and was able to clear check engine light with Edge Insight CTS (color touch screen) which I simply use for instrument cluster, reading and clearing codes. Truck seems to be running fine now with no alerts or check engine light etc., however, when I really get on it instrument cluster is still alerting a fuel pressure issue (p008A fuel pressure too low). I believe there is probably still a small amount of air in there. Is this something that will simply resolve itself with driving or do I need to bleed the line? Thanks, G.
Old Sep 5, 2016 | 11:01 AM
cappa's Avatar
cappa
As long as the primary fuel filter is butted up to the stop and the seal is good there, I. e not sucking air, you should be able to cycle the key over and over till you hear all the air bleed out.
Old Sep 5, 2016 | 11:02 AM
mtnbkr909's Avatar
mtnbkr909
Yeah, did that. Just wondering why my cluster is still registering low fuel pressure when I accelerate hard. Never did that before.?
Old Sep 5, 2016 | 01:09 PM
cappa's Avatar
cappa
The two problems i have heard about with changing the filters are the primary filter not completely sealing and allowing air to be sucked into the system, which is what it sounds like to me. The other is the quick connects under the hood not being fully seated and popping off, don't think this would cause a low pressure code thou. Sounds like you checked and sealed the primary thou so i'm not sure. You got lot's of fuel in the tank? Maybe try cycling the key a bit more with lot's of fuel in the tank.
Old Sep 5, 2016 | 01:33 PM
mtnbkr909's Avatar
mtnbkr909
Thanks. Anybody have any idea what Fuel Rail Pressure should read at idle?
Old Sep 5, 2016 | 01:41 PM
cappa's Avatar
cappa
Mine jumps around between 4000 and 4200 on a 15
Old Sep 5, 2016 | 03:11 PM
mtnbkr909's Avatar
mtnbkr909
Sounds about right. Thanks.
mtnbkr909
Sep 6, 2016 12:35 PM
Dave R.
Jul 24, 2013 05:27 AM
weldworks54
Oct 9, 2011 06:54 PM
vervloet
Jun 26, 2006 08:58 AM
muddingmcdude
Jun 12, 2006 09:31 PM
