Fuel Regulator air bubbles
Old Oct 9, 2011 | 05:05 PM
weldworks54's Avatar
weldworks54
I changed out my thermostat to do and while I had the tools out and some time on my hands. I went ahead and checked the fuel pressure regulator for air bubbles and i don't know if this is normal? What I found with upper filter out. KOEO while fuel was pumping in the fuel was full of air bubbles " looked like a drink that had been shook up" when that all settled out I got some air bubbles out of the largest metal line back into the regulator. I wish I could post a picture! What could be causing the air bubbles coming from the pump? Or is this normal? I am guessing the the last air bubbles are from a injector o-ring? And lastly could this be my bucking and jerking problem I've been having? The fuel pressure is 64 psi
Old Oct 9, 2011 | 05:34 PM
Unrealo4's Avatar
Unrealo4
You're injectors would be suspect if you were cranking while bubbles were present. At KOEO that would be fuel pump related. Possibly a cross threaded fuel filter lid on the HFCM.
Old Oct 9, 2011 | 05:50 PM
weldworks54
I checked it and actually torqued it witha torque wrench just to be sure it was tight
Old Oct 9, 2011 | 06:11 PM
cheezit's Avatar
cheezit
you need to check this with the system closed using a clean line.
Old Oct 9, 2011 | 06:54 PM
weldworks54
Cheezit sorry but I don't understand. hook a clear line in to the test port? I am also hearing a slight sucking noise at the upper fuel pressure regulator. Cap isn't cracked I just replaced it and o-ring looks good
Dave R.
Jul 24, 2013 05:27 AM
fixxxer-upper
Dec 14, 2011 11:30 AM
natedog37
Jan 11, 2011 07:34 PM
Krupka
Feb 25, 2008 08:06 PM
vervloet
Jun 26, 2006 08:58 AM
