2011 6.7 dropped #5 cylinder
Old Sep 4, 2016 | 09:44 AM
Nu2deisel's Avatar
Nu2deisel
while traveling through California my 2011 6.7 suddenly lost power, started making noise and then stalled out.
After finding out that there are zero 24 hour service companies available in the LA area, I was able to get it towed to the local Ford dealer.the next day they told me it had dropped the #5 cylinder and that they would have to tear into it to find out what happened.
While I realize that any thoughts on the situation would be primarily idle speculation, I was curious if anyoen had similar experiences or might have an idea what would cause this to happen at only 125,000 miles.
Any thoughts or comments would be greatly appreciated.
Old Sep 4, 2016 | 10:38 AM
Mike189677's Avatar
Mike189677
If it's an early build 2011 I would guess that it was a case of the bad exhaust valves the mileage is right seems to happen between 80-140k
Old Sep 6, 2016 | 10:57 AM
Nu2deisel's Avatar
Nu2deisel
Would it require a new engine if that is what happened?
Old Sep 6, 2016 | 11:40 AM
r2millers's Avatar
r2millers
Nope, not at all. If just an exhaust valve, the head would have to be pulled. The valve replaced, cylinder head seat ground, and most of the work from there pretty minor.
If however, it's a ring compression issue, then the engine must be pulled.
Old Sep 6, 2016 | 12:20 PM
sammy77's Avatar
sammy77
Our '11 had 363,000 miles on it when it happened. It was a car hauler it's whole life. The valve dropped into the cylinder and did quite the damage. We replaced the engine.
Old Sep 6, 2016 | 12:49 PM
rossterman's Avatar
rossterman
Valve dropping can result in piston/cylinder damage requiring extensive repairs or replacement. Occasionally people,get lucky and only need a new head but these folks are typically in the minority.
Old Sep 6, 2016 | 07:25 PM
Nu2deisel's Avatar
Nu2deisel
Well, the dealer opened up the oil pan and it was full of metal. Pretty well shelled. They are talking long block for around $12,500 plus labor. That is about $5000 less than a crate motor.
Which way shoudl I go with it?
Old Sep 6, 2016 | 07:45 PM
glenntorinosport's Avatar
glenntorinosport
REALLY 12,500 plus labor for a long block, Id be asking them why an optional engine is only about 8500. sounds like that dealer wants to make a bundle off you
Old Sep 6, 2016 | 07:50 PM
glenntorinosport
I meant the diesel option,and thats 5 grand less than a crate motor. sorry if I sound crass but dealers really ***** me off with thier pricing
Old Sep 7, 2016 | 12:46 AM
sammy77's Avatar
sammy77
These things aren't cheap. We replaced the engine ourselves for $8k ish. That was a reman from Ford with a warranty. We sold the truck shortly after that.
Old Sep 7, 2016 | 06:47 AM
TallEddie1981's Avatar
TallEddie1981
I don't think you can use the diesel option price to determine the cost of the motor. Don't forget, the base price of the truck includes the 6.2 gas motor. So the diesel option price is really saying the 6.7 costs 8500 more than the 6.2, not that the 6.7 engine itself is 8500.
(edit to add) - Of course, the engine isn't the only factor for the price difference, as there is a different exhaust system and probably some other parts. But my main point is that the diesel engine is not 8500 by itself.
Old Sep 8, 2016 | 04:59 PM
Nu2deisel's Avatar
Nu2deisel
There was a call put in to Ford CSM. They called and left a voicemail. I have called them 4 times now and still not return call. Is that standard for them?
Old Sep 8, 2016 | 05:13 PM
knightrider955's Avatar
knightrider955
You need to call Powerstroke Specialty in Buford Georgia and talk to Bill Hewitt ASAP! 770-904-0733
Old Sep 8, 2016 | 06:07 PM
Mike189677's Avatar
Mike189677
Haha that would be the last guy I or most people on this forum would call. Not to mention the op's in L.A.
Old Sep 8, 2016 | 08:41 PM
Nu2deisel's Avatar
Nu2deisel
What will he be able to do for me?
