Will 325/55/22 work??
Old Aug 16, 2016 | 10:42 PM
hwybee22's Avatar
hwybee22
I recently purchased used 22x12in rims with 325/55/22 and he left the tires on the rims because they was just collecting dust. The rims did not have any damage and was holding air. My question..on a stock suspension, can I use those tires since they're a D rated tire and so big? I would love to get away without buying new tires. I'm working on the road and wished that I could just put them on to see they would work. Also, after doing the front end conversion, I gained maybe 3 inches between the front bumper. Thank you and I'll look forward to your answers.
Old Aug 16, 2016 | 10:59 PM
pirate4x4_camo's Avatar
pirate4x4_camo
That is equivalent to a 36 x 13 tire.
Me thinks you will need some lift and or trimming to fit those
Old Aug 17, 2016 | 10:46 AM
hwybee22's Avatar
hwybee22
Can I safely run a D rated tires?
Old Aug 17, 2016 | 11:14 AM
pirate4x4_camo
A 325/55/22 tire has a load index of 117
At 50 psi it is rated for 2835 pounds per tire.
Assuming your Excursion doesn't weigh more then 11,340 lbs then a load range D is fine. ( mine came from the factory with D's )
Old Aug 17, 2016 | 01:09 PM
hwybee22's Avatar
hwybee22
I knew that I could count on you pirate!!
Old Aug 19, 2016 | 02:06 PM
Peace2Peep's Avatar
Peace2Peep
Pictures!
Pictures!
Pictures!
BTW: They definitely WON'T fit without some amount of lifting...sorry!
Old Aug 19, 2016 | 03:53 PM
hwybee22's Avatar
hwybee22
Originally Posted by Peace2Peep
Pictures!
Pictures!
Pictures!
As soon as I get home at the end of this month, I will. If I drop down to a 50 series or maybe lower, do you think it would work?
Old Aug 19, 2016 | 09:57 PM
Peace2Peep's Avatar
Peace2Peep
At one point I ran a 305/45/22 but they were somewhat rubber-band-ish. It will rub with 50 series, but I am more of a person to put them on and then make the adjustments necessary. No point lifting or bending/reshaping things more than necessary.
Old Aug 20, 2016 | 11:11 AM
hwybee22's Avatar
hwybee22
Where does it rub? And you're recommending not to go with a 45 series.
Old Aug 20, 2016 | 09:10 PM
Peace2Peep's Avatar
Peace2Peep
I would only recommend 45 series if you will NEVER go off-road. They are pretty thin and will be a bit sporty of a ride. The 50's are a bit more cushy and much better for off-road.
Gf2501
18
Jun 3, 2018 06:30 PM
hwybee22
Dec 18, 2015 11:17 AM
NV250
Sep 25, 2008 03:56 PM
F350Dual E
Aug 17, 2004 12:00 PM
f150-az
1997 - 2003 F150
Jul 17, 2003 03:43 PM
