Rear door rocker replacement?
Old Aug 14, 2016 | 08:55 AM
p33tef's Avatar
p33tef
Hi has anyone had to replace the rear door rocker panels, any suggestion for where to purchase and what cost to get them replaced
Old Aug 14, 2016 | 09:05 AM
DavenTn's Avatar
DavenTn
I replaced mine... less than $50 bucks each, available everywhere. I cheated and riveted the top and welded the bottom. Came out perfect.
Bought the rattle can paint from Amazon, primer, base coat, clear coat. $40 I think
Old Aug 17, 2016 | 12:49 AM
HiZ's Avatar
HiZ
Need to do mine from WI salt. Low miles but guy that had it used for snowmo trips. I'm game to watch and learn with you. If it was a boat and had gel coat with fiberglass I'd be all over it!
Old Aug 17, 2016 | 10:07 AM
freesoul's Avatar
freesoul
video tutorial please
my driver side is rusted
Old Aug 17, 2016 | 12:42 PM
DavenTn's Avatar
DavenTn
I just drilled out all the spot welds, remove the old one, cleaned up the inner rocker with ospho' primed, painted and then applied Boeshield. Fitted the new rocker panel, riveted the top (along the body seam under the door gasket) in the drilled out holes, used 3M 5200 as body caulk, 2 rivets in the bottom and tack welded the remaining drilled out holes along bottom, painted and undercoated. I added the rubber "protectors" later after the paint cured. Bought a roll of the stuff... works great looks good.
Old Aug 17, 2016 | 12:47 PM
DavenTn's Avatar
DavenTn
Here's the rubber stuff, Safe Way Traction 6" X 12' Foot Roll of Black Rubberized Anti Slip Non Skid Safety Tape 3510-6-12
Old Aug 18, 2016 | 10:19 PM
HiZ's Avatar
HiZ
Yeah, that was a different language: I understood all of the words and the how to do those things, just the application and what and how was different.
HiZ's Avatar
HiZ
pics all done?
reddogracing
Jun 24, 2017 04:19 AM
Rusty_S
Nov 6, 2016 09:59 PM
dbeers02
WTB - Parts & other
Jan 26, 2014 12:31 AM
drdave
1997 - 2003 F150
May 22, 2009 04:55 PM
norman
Aerostar
Jul 13, 2001 01:58 PM
