Looking for New Carb with a rear vacuum port
Old Jul 31, 2016 | 09:29 AM
Musejaw's Avatar
Musejaw
Question Looking for New Carb with a rear vacuum port
I just did a power front disc brake conversion from master power brakes on my 69 f100 360 Auto. I've read the booster is supposed to have its own vacuum line, but I did not have any extra ports. So I connected it to the intake manifold, which was already going to 2 other things (one I believe is to the transmission). The booster works perfectly , but now the transmission seems to only shift when I do it manually. It was shifting well before. So now I'm just looking for a new carb with a vacuum port on the rear. Not looking for anything fancy or any added HP. Right now it has a 2 barrel from "Fred jones mfg". Any recommendations? (I have dual headers/dual exhaust)
Thanks!
Old Jul 31, 2016 | 11:25 AM
351Cleveland C4's Avatar
351Cleveland C4
Get a vacuum spacer...
Old Jul 31, 2016 | 12:11 PM
Musejaw's Avatar
Musejaw
I've got a spacer on there already with 2 ports. One for PCV and one for hot water. Do they make spacers with 3 ports? And is that ok to use? Or should I just bypass the hot water and use that port? I live in central Texas. It gets hot. Do I need that hot water?
Old Jul 31, 2016 | 12:17 PM
351Cleveland C4
Get a different spacer. The one you have isn't what you need.
Old Jul 31, 2016 | 02:06 PM
Jklnhyd's Avatar
Jklnhyd
The hot water port is not for vacuum, so if you hook it to your booster your booster will be filled with hot water. No bueno.
Old Jul 31, 2016 | 03:05 PM
351Cleveland C4
Could you take a picture of what you have? I'm surprised the carb doesn't have a large vac port built into it.
Old Jul 31, 2016 | 06:06 PM
Musejaw's Avatar
Musejaw
Is it possible to do multiple spacers for an extra vacuum port?
Old Jul 31, 2016 | 06:49 PM
351Cleveland C4
Possible? Yes.
Good idea? No.
Where are your other vacuum lines hooked up?
Old Jul 31, 2016 | 07:26 PM
Ford_Six's Avatar
Ford_Six
You need a vacuum tree for the booster. It threads into one of the 3/8" npt ports in a runner. Most carbs say not to use the base or spacer port for brake booster, when you let off the brake and the vacuum booster equalizes, it can mess up the vacuum signal to the carb and cause a stall or stumble.
Old Jul 31, 2016 | 09:45 PM
Jklnhyd's Avatar
Jklnhyd
Not the greatest pics, but you can see what the vacuum tree looks like with stock pb.
Kyle Wood
20
Mar 21, 2025 07:41 PM
NateTheGreat
Feb 9, 2015 09:08 AM
79super460
Oct 19, 2012 12:39 AM
limpysmalls
May 7, 2012 09:46 AM
GeneStoner
13
Mar 6, 2003 09:53 PM
