Identicator Light in Grille problems
Old May 6, 2016 | 09:15 PM
Mustangking1's Avatar
Mustangking1
Hi,
My 78 f250 and even my dad's 71 Mustang are having the same problem the bulb in the driverside front grille keeps burning out blue. I even changed the turn signal socket. I also cleaned the grounds and checked for shorts. Still blows both filliments, cracks or breaks the glass and turns the bulb blue.
What is going on? How do I fix this?
Old May 6, 2016 | 10:42 PM
orangeford's Avatar
orangeford
Only thing I can guess from what you described is check voltage at sockets. See if it is higher than 14 V or so. If so your voltage regulator could be bad and needs replaced. I had mine go out and my lights got bright and then burned two headlights out.
Make sure your fuses are sized correctly too.
Old May 6, 2016 | 11:07 PM
Mustangking1
Voltage tested the socket, here are the results.
Truck engine off, identicator light has 12v, turn signal goes 9v 5v 1v off
Truck engine on idling, identicator light has 14v, turn signal has no voltage.
Does that sound like a bad voltage regulator?
Old May 6, 2016 | 11:13 PM
orangeford's Avatar
orangeford
No that should be ok. When my voltage regulator went out I was seeing 18 volts on my aftermarket gauge. Lights were nice and bright for a moment then died. I have a 3g alternator.
Turn signal should only have voltage when signals are being activated.
I really don't know why they would burn out unless the fuses are oversized.
Old May 7, 2016 | 04:18 PM
Mustangking1
Fuses are correct size. Any other ideas?
Old May 8, 2016 | 12:04 AM
dads1977's Avatar
dads1977
is yours and your dads light switch possibly dirty?
(i.e. dust and grime build up between posts)
have you tried replacing the turn signal switch?
or checking for a short in the steering column wiring?
or how about both relays under the dash?
is your ignition switch sticking in between the start and run position?
are you trying to use after market "brighter" bulbs?
Is it just your fronts that keep blowing? maybe you have a bad wire or ground at a rear or side light.
767679ford
Nov 16, 2009 06:25 PM
prmac
1983 - 2012 Ranger & B-Series
Jul 13, 2007 12:19 AM
cmask
Aug 31, 2003 06:19 PM
customline
May 17, 2002 01:11 AM
robie
Electrical Systems/Wiring
Jul 18, 2000 09:36 PM
