Restarting 7.3 after replacing high pressure oil lines
Old Jan 24, 2016 | 04:16 PM
Clarkcoplan's Avatar
Clarkcoplan
Hi all. I have a 2000 7.3. I blew a high pressure oil line while driving and the engine died. Replaced those now the truck won't start. Read a previous thread about turning the key a few times to get the oil pump working again. Tried that, pump makes gurgling sound but the starter is not engaging. Could I have blown a fuse? Cleaned all connections so I don't think that's it... Please help!
Old Jan 24, 2016 | 06:12 PM
Tom's Avatar
Tom
Moving to the 7.3L forum.
The high pressure oil pump is gear driven, it's not doing a thing unless the engine is spinning. If the starter isn't turning the engine you have a different problem. Can you hear the starter motor turning? Try whacking the starter a few times, sometimes that will get a sticky solenoid or bendix going again.
Old Jan 24, 2016 | 06:22 PM
guitarpicr's Avatar
guitarpicr
Is your oil back to full - How much did u lose initially. These trucks have to have a certain amount of oil to start (cant remember the exact amount)
Old Jan 24, 2016 | 09:26 PM
Tugly's Avatar
Tugly
If the starter isn't cranking, try shorting the relay on the passenger fender (this is how I crank the engine when doing compression tests). If that doesn't work, your problem is down below.
soco
Apr 7, 2014 03:40 PM
tcrouse7813
Apr 28, 2013 01:19 PM
wade456
Jan 5, 2007 06:42 AM
dieselgirl
Dec 23, 2003 02:28 AM
hopro
Oil & Lubrication
Sep 6, 2001 01:04 PM
