Tach and Temp gauges not working!!!
Old Jan 9, 2016 | 10:19 PM
Matt Manley's Avatar
Matt Manley
Hello, My right side of my instrument cluster is not working. the Tachometer, Engine Temp and Trans Temp gauge are non responsive, and the CEL and Check gauge light is on. I have seen other posts with people that had the same problem but no solution to what fixed the problem. Any help would be appreciated. 2004 F250 Lariat.
Old Jan 9, 2016 | 11:22 PM
78fordman's Avatar
78fordman
What code is set?
Old Jan 9, 2016 | 11:58 PM
Matt Manley
U0155 is set, However I have tried another cluster and the problem still is there. Its not a bad instrument cluster. The gauges will do a sweep. Its gotta be something simple. Like I said I have seen this same problem posted by others but nobody replied back and they didn't respond back to how they solved this problem or fix.
Old Jan 10, 2016 | 06:51 AM
78fordman's Avatar
78fordman
This is a start. https://www.ford-trucks.com/forums/1...r-cluster.html
Old Jan 10, 2016 | 07:53 AM
DSMMH's Avatar
DSMMH
If you have access to wiring diagrams, check for a relay in the circuit. That is usually the simple fix. I lost my panel, radio and the interior lights were on all the time. The fix was to replace the time delay relay. Whenever I have an electrical problem, the first thing I look for in the circuit is a relay.
Ed
Old Jul 18, 2018 | 09:23 PM
Jeff Tarantino's Avatar
Jeff Tarantino
Update?
Wonderimg if you ever came to a conclusiom with your issue? I have the same issue going on, already had cluster rebuilt, new pcm, still same problems. Was told might need pcm flashed ffom ford with ford software. Just wondering what your outcome was. Thanks
Brian Ski 44
19
May 31, 2017 06:37 PM
04MWCC
Jan 11, 2016 05:39 AM
InfantryCPT
29
Apr 15, 2015 01:19 PM
Shooter00
May 11, 2010 10:33 AM
MRStace84
Jun 13, 2005 08:45 PM
