I have a 2006 F250 with the rear driver side window that goes down but not up. I bought a new regulator and hooked it up to power before going through the trouble of removing the old one. It traveled down and wouldn't go up. The switch is working because I have power to it and thru it. Does anyone out there know what it might be?
Up side of the door switch. Is this true for both the door switch and the drivers side door switch or just one? If both its either a fuse or a wire, if one its that switch?
Thanks Yahiko. Is there a way you can load some of these very helpful things in the tech folder? Thy really do help figure these electrical things out. I have benefitted from many of those posts by you, so thanks!
I have thought about that a few times myself but don't have a clue on how
to go about it. Maybe one of the mods could give some input on that. I have
no problem doing it.
One thing I could do is start some threads by year and post the PDF diagrams
that way and then one of the powers that be can move it to the Tech Folder.
WHat do you think?
Would be nice to be able to easily link back to a PDF file that is already uploaded.
Give me a little time to look at how I have it setup here on my end. Right now I
have a directory for each year and some sub directories for things like 4X4 and
stuff like that.
