fuel smell?
Old Aug 5, 2003 | 12:07 PM
truogj's Avatar
truogj
fuel smell?
I just replaced the spark plugs, plug wires, and distributor cap in my 94 F150 with the 300 I6...also put a K&N airfilter in it. Now when i start the engine I notice an unburnt fuel smell which goes away but comes back when i rev it in neutral.....i checked to see if the plugs were seated correctly and they are....and there is no noticable fuel leaking anywhere. any ideas?
also, there is a slight hesitation when I romp on it in neutral but it revs up smooth with smooth pedal depression. any ideas about that and could the two be related? could it be injectors? i'm going to run a bottle of injector cleaner thru it....other than that, i'm lost. any help would be appreciated....thanks
Old Aug 9, 2003 | 12:58 AM
LxMan1's Avatar
LxMan1
fuel smell?
Make sure that the air intake hose is secure and that there are no vacuum leaks. A leak between the throttlebody and the mass-air sensor will make them run bad.
Also, clean the mass-air sensor. It make have a small oil film on it fron the initial start-up from the new filter.
Jimmy
Old Aug 9, 2003 | 10:34 AM
truogj's Avatar
truogj
fuel smell?
thanks, jimmy, i'll give that a shot....i gapped the spark plugs a little wider and that took care of the hesitation and some of the fuel smell, but it's still there sometimes
Preemo
25
Jan 26, 2015 09:32 AM
jim33067
Aerostar
Aug 24, 2012 10:21 PM
cartmanea
Aug 29, 2009 04:06 PM
86stepsideF150
64
May 17, 2009 04:44 PM
countryF150
Apr 14, 2007 10:12 AM
