2011 f350 king ranch NO HIGHBEAM, low beam, fog lights
Old Oct 24, 2015 | 11:38 AM
Bryonseng's Avatar
Bryonseng
Hello all first off I deeply appreciate any and all comments on this thread. You all are great for the help. I have DRL, turn signals and tail lights. I have checked all fuses ( don't know if there's a relay) under hood and in cab. Still do not have any headlights, high or low beam nor do I have any fog
Lights. Any suggestions?
Old Oct 24, 2015 | 01:24 PM
Just Strokin's Avatar
Just Strokin
If you turn the light switch to Park lights, do they come on?
Old Oct 24, 2015 | 02:03 PM
Bryonseng's Avatar
Bryonseng
Only my DRL come on
Old Oct 24, 2015 | 05:15 PM
Just Strokin
Makes me wonder if you have a bad or loose connection on the Steering Column Control Module. Check the light switch and the wiring to the SCCM on the steering colmun for loose connections or loose bad grounds.
Connectors C2414A, C2414B are located on the top of the steering column behind the clock spring. Connector C205 is on the light switch.
Old Oct 24, 2015 | 05:57 PM
Bryonseng's Avatar
Bryonseng
Thank you Larry. I will check it first thing tomorrow with my voltmeter. I truly appreciate your time and suggestion. Just bought it used in Texas. Trying to get home in northern il and this **** happens. I will let you know how it goes
Old Oct 27, 2015 | 02:10 PM
Bryonseng's Avatar
Bryonseng
Ok. After much investigation and anguish I have replaced all my lights that were out. Side marker, mirror marker and my headlights including my fog lights were out. I seem to find that when I use the remote start my sunroof fuse pops. If I get in and turn it on everything stays legit. Can't seem to tie all this together
d_gant
2004 - 2008 F150
Aug 2, 2016 08:34 PM
jlmotox
1997 - 2003 F150
Feb 10, 2008 10:10 PM
farwhitenorth
Jul 26, 2007 08:23 PM
hardnapalm
Electrical Systems/Wiring
Sep 16, 2005 07:41 PM
mickyDeez
Dec 29, 2003 06:14 PM
