Automatic for 226 6 Cylinder
Old Sep 14, 2015 | 04:15 PM
rswhitmore's Avatar
rswhitmore
I am looking for some information on what automatic transmissions will bolt up to a 1950 226 flathead 6 with minimal modifications and expense. I have a 2 speed Ford-O-Matic out of a Falcon. The truck has a 4 speed crash box transmission, and I am looking for a cheap, more user friendly transmission so the rest of the family can get in it and drive. Hopefully someone has been down this road and can offer some advise.
Old Sep 14, 2015 | 08:33 PM
52 Merc's Avatar
52 Merc
You didn't say what model/series of truck you're working on. it will make a difference with the answers. No modern automatic transmission will bolt up to the 226 without an (expensive, if you can find one) adapter. Even if you found the one rare unit that would have come in a 1951 car with the 226 (one year only) it still wouldn't fit in the truck chassis without crossmember modifications.
The simplest swap would be with a syncro truck 3 speed in place of the crashbox.
Old Sep 14, 2015 | 08:57 PM
rswhitmore's Avatar
rswhitmore
226 Transmission
The truck is a 1950 F2 with a 4 speed crash box transmission. A 3 speed unit like you described sounds like a good option. Would this be a bolt-in? Any particular transmission to look for? Would it use the stock clutch? Any advice is appreciated.
Old Sep 14, 2015 | 09:31 PM
38 coupe's Avatar
38 coupe
Actually Ford never did install the Ford-O-Matic behind the 226. You had to wait to 1952 and the 215 valve in head engine to get an automatic behind a Ford six cylinder.
You could work with one of the companies offering C4 or AOD to flathead V8 kits. You need a six cylinder specific flex plate, then I think the rest of the kit would work with the truck bell housing.
Old Sep 15, 2015 | 10:35 AM
harleymsn's Avatar
harleymsn
As far as I known, from my research of available kits for my 8BA/AOD conversion, none of the kits will work with the 226. Nor do they offer any way to make it work.
Old Sep 15, 2015 | 04:52 PM
38 coupe's Avatar
38 coupe
Yes. The bell housing problem is solved by using the truck bell housing that replicates the 32-48 block. The starter is the same as used on the V8s so that is fine. It is the flex plate that noone makes for the flathead six. Here are two kits that would probably work except you get to figure out the flex plate:
http://www.flatheads-forever.com/web...product_id=207
Flathead to C4 Transmission Adapter Kit - 1941-1953 Ford - Hot Rod Parts
Old Sep 15, 2015 | 07:52 PM
harleymsn's Avatar
harleymsn
C4 Adapter Kit
Those are both Flat-O-Matic units The Flat-o-Matic You can contact them and see what they say.
Old May 19, 2016 | 08:52 PM
balvord's Avatar
balvord
I have a 1950 ford f-1 it has the flathead six 226 engine in it. I also has the three speed transmission. It's all original. The engine was rebuilt three years ago. I'm wanting to run it on the highway at a faster speed. I'm thinking the T-5 transmission but what all do I need to make the swap? Any help would be appreciated. Not sure what all I would need to do. Can I still use the original drive shaft and rear end? Thanks
Old May 20, 2016 | 02:22 AM
FortyNiner's Avatar
FortyNiner
Welcome!
A couple of comments:
The tranny change isn't the best move for speed, you should consider a rear end swap. Look here for guidance: 1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps - Ford-Trucks.com
With higher speed, often comes a desire for better brakes, steering, seatbelts, and tires...
A proper welcome is in order, it is best to start a new thread and introduce yourself, your truck, and post a pic (or three) of your the '50.
Old May 20, 2016 | 07:34 AM
Jules The Great's Avatar
Jules The Great
Are the 226 and Flathead bolt patterns the same with just a different input shaft length?
Robhudson
Nov 8, 2015 08:04 PM
hellbound_redneck
Dec 28, 2009 09:33 PM
Greywolf
1983 - 2012 Ranger & B-Series
Jun 10, 2007 09:32 PM
Widall
Mar 29, 2005 08:43 PM
Kurts50
17
Jun 25, 2002 11:18 AM
