Replacing oil bath air cleaner
Old Aug 31, 2015 | 06:48 PM
52flatheadf1's Avatar
52flatheadf1
On my 239, I want to eliminate the oil bath air filter and replace with a direct fit air filter...any suggestions on air cleaners that will fit properly?
Old Aug 31, 2015 | 07:15 PM
toby tough's Avatar
toby tough
I think 52 Merc did a mod to an old oil bath unit. Used a Fram filter in it. Check out his thread. Pretty good stuff there. Haven't quite figured out how to post links yet but you can use the search function to find it.
Old Aug 31, 2015 | 07:18 PM
3twinridges's Avatar
3twinridges
Yes, that post about the mod is great, I just followed it and the results are outstanding. It does take a while to cut with a hacksaw but really is the best way.
Old Aug 31, 2015 | 07:56 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Here's the link to Wayne's mod.
https://www.ford-trucks.com/forums/1...r-cleaner.html
Old Aug 31, 2015 | 10:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If you look at your carb's air horn, you'll see it has a wedge-shape for the V-clamp on the air cleaner. No aftermarket air cleaners are going to fit securely to that, although some of the small dome-shaped ones with set-screws might stay on acceptably well. Wayne's mod is the best bet.
Old Sep 1, 2015 | 12:03 AM
52 4x4's Avatar
52 4x4
Since I've had it, my truck has always had an 8BA car carburetor on it. The car carburetor doesn't have the wedge on the airhorn. At the time, you could buy a Balkamp adapter from NAPA that clamped on and provided a center stud for a standard air cleaner with a wing-nut. I used an air cleaner from a 283 Chevy (for Rochester 2GC) on mine. - Bob
283 Chevy air cleaner
Old Sep 1, 2015 | 11:10 AM
harleymsn's Avatar
harleymsn
Is that a 12v motorcycle battery mounted on the firewall?
Old Sep 1, 2015 | 12:21 PM
Indybeer's Avatar
Indybeer
I also modified mine using 52 Merc's post. However instead of using a hacksaw I used my high speed grinder. Much faster and turned out nice.
Old Sep 1, 2015 | 12:52 PM
52flatheadf1
I was just thinking the same thing.
Old Sep 1, 2015 | 02:28 PM
52 4x4's Avatar
52 4x4
Close! It's a 6V. The wires and fuses behind the air cleaner lead to a DPDT switch under the dash that allows me to power a 12V negative ground radio, or charge the battery if I don't want to play the radio. This also required converting the truck to negative ground. - Bob
Old Sep 7, 2015 | 02:13 PM
petemcl's Avatar
petemcl
I have a spare air filter assembly in good condition if you "make a mistake".
Old Sep 20, 2015 | 11:47 PM
gearhead1952's Avatar
gearhead1952
I've modified a few of the original oil bath. First one I did using a K & N filter but was too pricey ($55). Found a Napa gold element for $10 that works well.
F250Rob
44
Oct 11, 2017 08:49 PM
broken knuckles
Jul 12, 2011 02:42 AM
JRB65
Aug 5, 2009 10:47 AM
gregtx
Sep 17, 2008 07:49 AM
Olddog66
Jul 14, 2008 06:14 PM
