Steering Wheel Radio Control Harness
Old Jul 15, 2015 | 04:49 PM
nagetech's Avatar
nagetech
Hey fellas
I am in the planning stages of installing / upgrading my X's sound system.
This isn't the first time I've done an install like this before, but am running into a bit of trouble with the steering wheel controls.
I know there are options out there as far as interfacing, but my problem is finding the other harness.
To be more specific, I know if I pull my radio out, there are 2 harnesses back there. One is the one you get the kit and splice the after market radio into the factory harness. EASY I Know.
Now, do you guys know if ANYONE makes a harness that plugs into the other plug? I'm not a fan of cutting/splicing into factory wires. Most of the steering wheel control kits just require you splice with 2-3 pins on that other Plug and you should be set. I'd really love to just have another adapter that plugs into that harness so I can connect what I need.
Really hope you guys understand what I need and can help!
Thanks
Old Jul 15, 2015 | 04:55 PM
Archion's Avatar
Archion
Veteran: Marine Corps
I looked at all the normal suppliers, even a few of the more specialty ones. I do not see one.
edit: Maybe re purpose part of this depending on year...
http://www.sonicelectronix.com/item_...le-PXHFD3.html
Old Jul 15, 2015 | 05:02 PM
nagetech's Avatar
nagetech
Thanks for sharing that! I'm glad you know exactly the plug I'm talking about!!
I came across that adapter before. I believe the cables in the dash are female already aren't they? So I would need that 20 pin adapter in male form.
Old Jul 15, 2015 | 05:04 PM
Archion's Avatar
Archion
This looks to be a inline jumper harness for aftermarket source integration, it has both ends on it. I would just cut it and reposition pins as needed. Could also be used for other integration purposes as it gives accesses to the RES circuits, like the OEM DVD audio feeds. The small white plug is the male side and would plug into the truck, and the black is the female side that plugs into the OE head unit. with the molex style connector plugging into the aux source box. You would just cut off the pigtail and the white plug and use what you need.
Old Jul 15, 2015 | 05:05 PM
Drunken_Unicorn's Avatar
Drunken_Unicorn
They don't have one, sadly I looked and looked when I installed my stereo. Here is the video I used :
To get the steering wheel controls to work, you have to splice one of the wires from the factory plug.
Are you using something like this to make your steering wheel controls work?
Amazon.com : PAC SWI-PS Steering Wheel Control Interface for Dual/Jensen/Pioneer/Sony : Automotive Steering Wheel Accessories : Car Electronics Amazon.com : PAC SWI-PS Steering Wheel Control Interface for Dual/Jensen/Pioneer/Sony : Automotive Steering Wheel Accessories : Car Electronics
Old Jul 15, 2015 | 06:11 PM
DidieX's Avatar
DidieX
You can try this, it has 3 harnesses and one of them is a 20 pin, possibly the one your looking for:
705700 - *Ford, Lincoln, Mazda 1998+ Premium Sound System Wire Harness 5700 - METRA
I know that the usa spec ipod connectors come with a big harness with both plugs, male and female. Problem is I can't find one online, just the whole kit. Maybe give them a call and see if they are willing to sell you just the harness. Then you can just cut off the ones you don't need.
Old Jul 15, 2015 | 10:58 PM
hasteranger's Avatar
hasteranger
I ordered a kit years ago that came with two plugs but I never pulled the radio to check which ones it was. Now I can't find the kit. Getting ready to install my new head unit and I have the pwc adapter so looks like I'll be soldering. Side rant, it pisses me off that every parts store sells solder and none of them sell Flux anymore. Wtf.
kcschultz
Feb 15, 2020 01:38 PM
st8yd
May 16, 2014 11:28 PM
Person25
Jan 3, 2011 11:08 AM
Person25
2004 - 2008 F150
Jan 1, 2011 04:51 PM
DanzbigA250
Oct 15, 2009 12:01 AM
