Front Hub 4X4 Questions
Old Jul 15, 2015 | 06:06 AM
carbon coupe's Avatar
carbon coupe
Hey everyone. I recently experienced a strange happening. I had not been driving my truck very often, maybe once a week. I noticed a smell from the passengers side front wheel after driving it. I pulled the wheel off and found that the bearing had spit out all the grease through the back. I took it down to the bearing and when turning it, it seems a bit rough. I added new Mobil one red grease and it seems fine. No extra heat, measured with heat gun, after a 4 hour drive.
So my questions are:
1. Should I replace the bearing?
2. What grease does everyone use?
3. If I choose to replace, do I need to put all the ESOF stuff back in?...seal, washer etc... I have manual hubs.
4. Semi-related, how much play should there be, fully assembled, in the stub shaft in the back of the hub? (when I grab the U-joint, I can move it up and down a bit. U-joint tight, shaft seems loose in the hub, I'll check again tonight)
I rebuilt the drivers side completely when I bought it but the pass side was done when I got it. I have everything but the bearing and plan to do it all at once. Nothing else needs it yet but if I have hidden issues, I'll do the whole thing. Thanks for any insight.
Old Jul 15, 2015 | 06:19 AM
Bently_Coop's Avatar
Bently_Coop
Was the grease underneath the back side of the rotor?
1975stroppebaja
I used Valvoline Dura Blend grease for this as it meets the NLGI #2 Lithium Complex EP grease specs.
Here is a link from tech folder regarding greases and such. Also has links to FTE about the wheel bearings.
2004 F250 Front End Service
Old Jul 15, 2015 | 06:22 AM
harley4jcs's Avatar
harley4jcs
[QUOTE=carbon coupe;15502622]Hey everyone. I recently experienced a strange happening. I had not been driving my truck very often, maybe once a week. I noticed a smell from the passengers side front wheel after driving it. I pulled the wheel off and found that the bearing had spit out all the grease. I took it down to the bearing and when turning it, it seems a bit rough. I added new Mobil one red grease and it seems fine. No extra heat, measured with heat gun, after a 4 hour drive.
QUOTE]
1) yes, yes, & yes "MAYDAY! MAYDAY! MAYDAY!
Passenger front bearing seized, damn near threw Excursion off I-65 southbound just south of Greenville, Alabama.
In desperate need of help, be it a jack and stands loaned and a ride to the parts store or a tow someplace safer."
2) Mobil 1 is hard to beat. I.M.H.O. Was my choice.
3) don't HAVE to
4) don't know BUT don't think you should be able to move it around by hand either...Can you wiggle the other side as well ???
Old Jul 15, 2015 | 06:33 AM
carbon coupe
Yes, the grease came out of the bearing on the back side between the stationary part and the rotating part. It was not on the brakes but everywhere else. Messy. Nothing now.
Im leaning torward rebuilding the whole thing, new bearing and all. I have a couple of long road trips coming up, one to Denver, and dont want any issues.
Both sides seem to be equally 'loose'.
Old Jul 15, 2015 | 06:51 AM
Bently_Coop
Mine did the same after I filled it with grease. I cleaned it up and have left it alone since, been a month with out issue so far. Knock on wood.
Old Jul 15, 2015 | 07:02 AM
carbon coupe
This was just random though, like suddenly it rejected the grease while sitting. While filling it, I pumped until it just started creeping out the back, cleaned it up again and reassembled. No issues since.
I just ordered a new bearing. If I have time, I may rebuild the corner this weekend. Im going to keep the one I take off for the shelf.
Old Jul 15, 2015 | 07:08 AM
Bently_Coop
I did the passenger wheel bearing last year and pumped some grease into the driver side at the same time. In May I did some brake maintenance and noticed grease all over behind where the rotor is. Cleaned it up and haven't messed with it. I may have to slide under and see if grease is all over again.
Old Jul 15, 2015 | 08:25 AM
WE3ZS's Avatar
WE3ZS
I pumped both of my unit bearings full of red Mobil 1 grease about 3 years ago, full until I saw some creeping out the rear seals (about 22 to 24 pumps each). It has not ejected any of that grease since (or not up to the last time I was under there....). I think your plan to change that bearing out may be a prudent considering your long upcoming trips and Matt's recent bearing failure on the road.
I'll be rechecking mine for any grease ejection soon.
Old Jul 15, 2015 | 10:26 AM
carbon coupe
So reading that thread, it seems that the moly based grease is not recommended for these bearings. Unfortunately, thats what I put in last year. Well, new part on the way and I'll repack both with the proper grease when I do the RF corner.
Old Jul 19, 2015 | 10:53 PM
Bently_Coop
https://www.ford-trucks.com/forums/9...earings-3.html
Originally Posted by SpringerPop
It's getting close to the time for that annual reminder, guys........
One of my hubs (one of the OEM originals) now has over 237,000 on it, so I suppose we can put the debate to rest: Lubing the front wheel bearings through the ABS sensor holes WORKS!
Lithium-based, non-moly, NLGI #2, GC-LB
Mobil-1 (red) synthetic grease meets this spec, and is commonly available.
And.....
If you remove your hubs to do this (I don't), don't forget to lube those needle bearings that support the stub axle, too! These bearings are supposed to get lubed every 60,000 miles, anyway.
Now might also be a good time to lube those caliper slide pins, too!
Have fun!
Pop
bmwcarl
Mar 23, 2015 10:24 PM
airsoft1779
28
Dec 12, 2012 10:09 PM
drzg2000
Oct 29, 2011 05:41 PM
seaweaver
Nov 3, 2010 07:17 PM
rssnape
Dec 22, 2003 07:46 AM
