92 Ranger 2.3L fuel pump bad?
Old Jun 19, 2015 | 12:27 PM
Tomget's Avatar
Tomget
Truck quit running yesterday suddenly and unexpectantly. It sputtered briefly and the motor total quit running. I pulled over and tried to start and it briefly fired but then totally quit.
Got towed home. And now testing to see what all to repair..Thinking fuel.
I don't get any codes from the tester with KOEO..just the good to go etc..no codes or the good to go 111..etc.
Guess this problem can't be identified without motor running.
My wiring diagram doesn't give me all for my Calif car..I don't see where the relay is but my fuses are all good, and I'm getting voltage when I crank the motor at that inside firewall switch on both its wires(incoming/outgoing)..forget what its called..Inertia Switch?..that will shut off fuel pump during accident or impact etc. And I've read that this switch is upstream of the relay(if I read that post correctly) so guessing it's the pump itself that is bad.
Does that sound right? Should I go ahead and pull the fuel tank etc and replace the pump? Or is there more testing I should do?
When I turn the ignition key on..the pump makes zero sound. That's not the way it normally operates. Usually with the key on the fuel pump comes on momentarily and I can hear it.
Forget how to drain the fuel tank etc..I don't see a drain plug?
Any ideas? I did it once many years ago..but forget how haha.
thx Tom
Old Jun 19, 2015 | 02:34 PM
f5fordgirl's Avatar
f5fordgirl
Check the inertha switch to see if its tripped, then check the fuses in the box under the hood. Pulling the bed is lots easier than dropping the tank.
Old Jun 20, 2015 | 02:15 AM
KF4EYR's Avatar
KF4EYR
if you pull the bed it is a lot easier,,, 4 bolts in the bed, under back bumper unplug the tail lights, remove the screws from filler neck and you and a buddy pick up the bed and set off to the side,,,, fuel tank and fuel pump is right there to test and work on,, no need to drop tank,,,,
Old Jun 20, 2015 | 11:12 AM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Your truck may have two fuel pumps. My 89 4x4 2.3 liter did. One in the tank, and one on the driver side frame rail up by the engine. That fuel pump is a lot easier to get to and check.
Jim
Old Jun 20, 2015 | 11:49 AM
Tomget's Avatar
Tomget
Jim
Thanks but no I just have the one pump in the tank itself. I do have a fuel filter against the frame rail in the area you're describing, but no pump.
Bought a replacement pump yesterday and just now turned on the air compressor to hopefully allow my impact tool to loosen those ancient bed bolts. I did the best I could to get Blaster type oil on them, but hard to know how well I succeeded.
My plan is to loosen the bed bolts plus any electric connections that might be harmed in the process and instead of lifting and intentionally sliding back the entire bed itself, I'm hoping to see if I can use my engine hoist/cherry picker with a chain across the front area of the bed to lift it up enough for access to the pump. Meaning only lift the front of the bed and allow the back of the bed to slide around a bit as needed but not intentional slide it back or lift it..we'll see.
Don't know if it will work, but thinking if so it would be a good one man job method. We'll see.
Old Jun 20, 2015 | 12:01 PM
arctic y block's Avatar
arctic y block
Try hitting the tank in the area of the pump
with a hammer or base ball bat. Bang it hard
and most times the pump will start. This tells
me that it is for sure the pump. Have you checked
the pump pressure with a gauge at the shreader valve?
Will it fire with a little gas down the intake? I would hate
to see you change out the pump and find it was not
the problem like I and others have done a few times.
Old Jun 20, 2015 | 05:32 PM
Tomget's Avatar
Tomget
Thx I pretty much already did all that..its the pump..they die like us all.
Just finished the install and it was a snap as the pic shows..runs fine now. All done.
Old Jun 21, 2015 | 06:05 PM
Kruse's Avatar
Kruse
And the brand that you replace it with is......???
hcraw4d
Dec 30, 2012 05:53 PM
F250Highgirl
13
Dec 11, 2012 04:10 PM
chip99
Jan 9, 2011 03:30 PM
darklord
1997 - 2003 F150
Sep 9, 2009 10:25 AM
steve83
1978 - 1996 Big Bronco
Jan 8, 2003 07:42 AM
