Sponsored by: Auxito
No start_ Fuel Pump??
Old Sep 5, 2009 | 06:20 PM
darklord's Avatar
darklord
Confusing one this
Cranks but no fuel pressure at rail so started checking..
Relay OK, fuses OK, Inertia switch ok, feed to the fuel tank also ok (registers the same as inertia switch) .
Unplugged the feed plug to the fuel tank, and contacts looked dirty.
Cleaned them, and after a few tries, it starts.
I shut the engine off and it won't restart.
Clean the contacts again, and after many more tries it starts.
Lots of stop/starts no problems.
Leave it for 10 minutes, and it won't start again
If it had never started, I was ready to buy a fuel pump...but as I had some success...is a fuel pump still likely??
Maybe my contact cleaning is just a red herring? and the Fuel pump is intermittantly failing ?
Fuel pumps are expensive here $250, and I'm not looking forward to fitting one..hence my dawdling
Thanks
<!-- / message -->
Old Sep 5, 2009 | 07:53 PM
Mustang6147's Avatar
Mustang6147
Fuel pumps can be tricky... Dont buy them from Autozone.
SOmetimes they work and then they dont,, I have been told it is from dead spots in them, The old rule of them, is right under the gas tank, with the key on, you it the bottom of the tank with a rubber mallet right where the pump is, it will jar it, and get it to run, but if you shut it off, its dead again... It worked on a Chevy I had, never needed to do it on a Ford yet though...
Old Sep 6, 2009 | 06:27 AM
Joe Finn's Avatar
Joe Finn
Sounds like there's some room for doubt, but it sounds like a fuel pump to me.
Old Sep 6, 2009 | 11:35 AM
eallanboggs's Avatar
eallanboggs
If you traced all the way back to the connector there isn't much else left. When the pump IS working what is the fuel pressure? The commutator bars get pitted and don't always make good contact with the brushes if the motor stops at one of these bad spots. It may or may not restart the next time you turn the key. Once you get it going it usually keeps going, but not always. One some vehicles if only the pump motor is replaced it isn't that expensive, but if the whole assembly has to be replaced the price goes up. Pull the bed off. That makes the job a lot easier if you can get the bolts out. Sometimes they rust in place and shear off instead of coming out. Bad design. Keep your tank at least one fourth full. The gas helps keep the motor cool which extends the life. Run on fumes all the time and your motor will die sooner.
Old Sep 9, 2009 | 10:25 AM
darklord's Avatar
darklord
Update:
Mustang was right..a few 2x4 hits on the tank and it ran again. 5 hours later after a stop, it wouldn't go again.
Away from home, so got a local mech to do it. He managed to save me $100 on the parts..and I thought I had a good deal
He fitted a new fuel pump same day, and it's running again.
Thanks all again
AAAAAHAB
16
Feb 22, 2015 12:18 PM
Alto
1983 - 2012 Ranger & B-Series
29
Jul 6, 2013 10:16 AM
TheKhaos
Jun 21, 2013 01:04 AM
IBJanky
26
Jul 25, 2004 12:13 PM
emboyd
Aug 27, 2003 08:53 AM
