When "while I'm in there" goes wrong.. oil pan gasket
Did the rear main and oil pan gasket. I figured since I had the transmission out the oil pan gasket would be easier. Well, turns out it wasn't much easier although I had a bit more room.
I learned about the 4 piece gasket and how I'll need to either do some grinding or just replace the pan with an efi version to get a one piece.
I'm leaning towards simply buying a new pan unless anyone could convince me that Id be better off grinding the ridges off of my current pan, something that just doesn't sound comforting to me.
I've read that you have to hoist the engine out and I've also read that it isn't necessary. I know my drivers side mount is thrashed so I'll get one of those but I've only got 91k on the odometer so I'm wondering if it'll be best to do the pump also " while I'm in there " (that's an expensive phrase, isn't it?).
If you guys could help me decide and point me to a detailed thread on this topic I'd greatly appreciate it, as I know this subject has been covered thoroughly.
Thanks everyone.
P.s - clutch and flywheel ended up working great. Many thanks to those on here that assisted with experienced information. I'm relatively new to the shade tree mechanic life and without this site I'd have had a much more difficult time. Thanks again.
I searched and asked and was confident that enough guys had faced this task to know what they were talking about.
Fel Pro #OS 34601R includes the Snap-Ups, and will change your entire outlook on life; it makes that much of a difference.
I didn't hoist the engine, just jacked it up a bit. (**EDIT**) I also ground off the ridges/lips on the pan using a cheap non-Dremel; it wasn't nearly as difficult as I thought it would be.
A thorough step-by-step can be found on my build/resto thread, pages 46 and following:
https://www.ford-trucks.com/forums/1...roject-46.html
Since you typically need black RTV in the front and rear corners even with a one piece seal, dab the RTV in and then use some of the oil pan bolts to bolt the gasket to the block by itself (the gasket has metal inserts in the pan bolt holes). Come back the next day after the RTV has cured, take to bolts out, and install the pan.
I also did my oil pump "while I was in there", and have had no reason to regret doing so. I bought a new pan rather than dealing with grinding the ridges on the old one down.
That's your own fault for not borrowing the wife's camera phone.
Thanks everyone.
