Hi all 94 ranger 4.0l reg cab, 130k, am new to this forum ,my wife actually just picked up the truck, she had one a few years ago and loved it, anyway, needs a few things like, has a real bad fuel/exhaust smell/leak somewhere.?? power windows fixing, thats on the list, today i fixed the dome light($8) from junk yard, fix the passenger side speaker($4)
and we picked up some door panels in gray,current ones are red, but truck is black, so should look ok) they were $16 each, picked up a shifter for $8, good day picking at the yard. oh and i got an abs sensor for $4. not sure if i need it yet, my ABS LIGHT comes on when starting then goes off straight away as i suspect it should, but then after about 5 seconds comes on and stays on, i know nothing about this system so looking for pointers, is there a relay i can check? brake fluid is ok brake light came on when i dunked the float in the reservoir.
any input much appreciated. thanks.
Have a look in the Tech Info thread atop this forum's index page & scroll down to the brake section to find out how to pull your ABS system codes & post All code Number clues.
