1988 ranger 2.9l v6
Old May 10, 2015 | 08:08 PM
Caleb-'s Avatar
Caleb-
1988 ranger 2.9l v6
Help? I have no idea what's wrong and don't want to buy it with out knowing what I'm getting into
Old May 11, 2015 | 09:18 AM
tomw's Avatar
tomw
Likely the fuel pump is not getting the signal from the computer that the engine has started, so it does not enable the pump. The system will 'prime' for 3-5 seconds when the key is first turned from OFF to ON. The engine will start & run on that prime, but will fall on its face if the pump(s) are not energized after start.
You can bypass that with some switches & relays, not really thinking through the list of needed parts. One should not bypass the inertia switch on the floorboard behind the top of the carpet/mat, under the heater. It protects in case of accident or rollover.
The pump should be powered [via the fuel pump relay] when a jumper wire is put into the EEC-IV test port. It will run full time with a jumper used to retrieve codes, or should.
tom
Old May 12, 2015 | 06:32 PM
Caleb-'s Avatar
Caleb-
so I should be able to hot wire the solenoid and it should work?
cmaner24
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 24, 2017 01:13 PM
Lascar
Aug 27, 2016 04:23 PM
great8
Nov 2, 2010 09:43 PM
Bayer-Z28
General Automotive Discussion
Mar 21, 2010 01:08 PM
monarokid
May 20, 2009 12:36 AM
