Rear shocks broke
Old Apr 10, 2015 | 01:29 PM
Haywire-Powerstroke's Avatar
Haywire-Powerstroke
Rear shocks broke
so my truck seemed ridiculously bumpy and so i just assumed that the shocks were shot. well i was underneath the truck the other day and found out that neither one of the rear shocks are even connected to anything! on the passenger side i think i see were it is supposed to be mounted to but i couldnt find were the drivers side one is supposed to be attached. is this a regular thing to happen? and any suggestions on what the best way to put this back together would be greatly appreciated. ill try to get some pictures up when i get home later
Old Apr 10, 2015 | 02:21 PM
madMatador78's Avatar
madMatador78
You probably need new mounts, not a bad job, theres 3 rivets that you need to grind off, and then the new kit should come with the necessary hardware. I believe Dorman makes a shock mount kit. Ill see if I can come up with a part number. Its common up where salt is used, like here in Illinois.
I had an 83 F-250, it had the same issue. Had the job done in about an hour to hour and a half with a die grinder, and even put new shocks on in the process.
Edit: what year is your truck? also is it a 250 or 350? 2wd or 4wd, reg cab, extended cab, or crew cab Shouldn't make a difference, but doesn't hurt to be sure.
Old Apr 10, 2015 | 02:28 PM
madpogue's Avatar
madpogue
Are they detached from the frame and attached to the axle, or attached to the frame and detached from the axle?
Old Apr 10, 2015 | 11:55 PM
stainlessstroker95's Avatar
stainlessstroker95
Mine rear shock mounts rusted off also. I got my new ones from LMC.
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=51
#28 in the pic if you go back one page you will see the part number
Old Apr 12, 2015 | 01:30 AM
Haywire-Powerstroke
i believe mine are attached to axle and broke at the frame. the upper end of the shocks are not attached to anything
Old Apr 12, 2015 | 08:39 AM
madMatador78
Yeah, you more than likely need new mounts. Gabe there has a link, I'll see if I can find that Dorman number as well.
Old Apr 12, 2015 | 12:30 PM
Haywire-Powerstroke
Oh yea to answer your question from earlier it is a 97 f250 4x4 hd
Old Apr 12, 2015 | 01:25 PM
fordpride's Avatar
fordpride
Just a FYI when looking up parts for a 97 F250 look up a 96 it'll naje life easier.
Ford made HD and a LD. The LD is a f150 with a little beefier suspension
Old Apr 12, 2015 | 01:27 PM
Haywire-Powerstroke
Yea I hardly even bother with putting in 97 anymore haha
Old Apr 12, 2015 | 06:14 PM
madMatador78
Dorman Products - Search Results
Here you go.
Old Apr 12, 2015 | 08:51 PM
stainlessstroker95
Yeah dormans dormans from orileys would be the cheaper way to go. Good call Thomas, didn't know those were available when I got mine.
Old Apr 13, 2015 | 08:45 AM
LeoJr's Avatar
LeoJr
Haywire-Powerstroke, Methinks you need some near new Bilsteins for your brand new shock mounts....
Just a thought...
https://www.ford-trucks.com/forums/1...0-4x4-obs.html
Old Apr 13, 2015 | 10:25 AM
Haywire-Powerstroke
thanks for the help i think ill try to make it out to the store this week and get this done soon
Old Apr 14, 2015 | 07:21 AM
LeoJr's Avatar
LeoJr
Can anyone confirm what Bilstein shock they are using on a stock height truck like Haywire-Powerstroke has?
He is looking at my Bilsteins and I want to make sure they will work well for him. The shocks are:
Qty 2 P/N 33-185552 fronts
25.93 in./15.91 in. Extended/Collapsed
Qty 2 P/N 33-185569 rears
29.7 in./17.91 in. Extended/Collapsed
Thanks!
Old Apr 17, 2015 | 07:14 AM
LeoJr's Avatar
LeoJr
Anyone?
Thanks!
