Offroad & 4x4
F-250 L Front Axle Inadvertently Going into 4WD
Old Feb 26, 2015 | 03:19 PM
sparkypks's Avatar
sparkypks
The left front axle on my F-250 has recently been engaging on its own occasionally. The precipitating factors are always the same; hitting the brakes with a moderately rapid deceleration while turning left. As my speed gets to about 5MPH, it will feel like the truck is on ice on the L side as the truck seems to slip a foot or so forward during the turn. It is not on ice and not slipping.
After this sensation I can tell the front axle is engaged as I speed back up and hear the hum. When I stop and go into reverse, I can disengage the axle and all is back to normal.
The truck is a 1997 F-250 without manually locking hubs. 250K plus mile and other than that going strong. As I said, the problem is only intermittent and the only common threads are this turning deceleration. I would appreciate any help.
Thanks,
Pete
Old Feb 27, 2015 | 06:08 AM
tjc transport's Avatar
tjc transport
i ain't rite
defective automatic hub. put a set of manual hubs on and it will solve all your problems.
Old Feb 27, 2015 | 12:14 PM
82F100SWB's Avatar
82F100SWB
Unfortunatley there isn't much fixing to be done with the auto hubs themselves. The best repair is a set of manuals.
However, it might be worthwhile to pull the hub and spindle and check the bearing in the backside of the spindle that the axle rides in, when they go bad they can cause manual hubs to lock in on their own, so I could see it causing issues with an auto as well.
Old Feb 28, 2015 | 03:50 PM
sparkypks's Avatar
sparkypks
Thanks for the advice and info. Seems like a combination of left and forward inertia is the cause. Is changing to manual locking hubs difficult?
Thanks again
Old Feb 28, 2015 | 04:28 PM
tjc transport
i ain't rite
not really. just remove the auto hubs, cap off the vacuum lines, and install the new hubs.
just make sure you get ones to convert from auto to manual.
Old Feb 28, 2015 | 08:12 PM
82F100SWB's Avatar
82F100SWB
No vacuum lines on a 97.
Depending on which bearing retaining nuts you have you may need to change them. If you have a large hex spindle nut you will need to get a new set of manual hub style ones that use the 4 pin socket.
Old Mar 1, 2015 | 04:38 PM
Nothing Special's Avatar
Nothing Special
Depends on which '97 F-250 he has. If it's the light duty (looks like a '97 F-150) it probably does have a vacuum line. If it's a heavy duty (looks like the '92-'96 F-series and the '97 F-350) then it does not.
Old Mar 1, 2015 | 05:49 PM
82F100SWB's Avatar
82F100SWB
My assumption is a real F250, not a 7 lug F150, as they run a center axle disconnect, not locking hubs.
Old Mar 5, 2015 | 09:46 AM
sparkypks's Avatar
sparkypks
TJC, 82F100SWB and Nothing Special. Thanks so much for all the great info. Also found some great info on changing to manual on other FTE threads.
I really appreciate the help.
Old Mar 5, 2015 | 09:50 AM
sparkypks's Avatar
sparkypks
By the Way, no vacuum lines.
3 Bears
Jul 24, 2018 03:43 PM
greenman0013
Feb 20, 2017 08:32 PM
tim j s
Aug 13, 2010 05:14 PM
SLE
Jan 9, 2006 03:50 PM
spm4520
Offroad & 4x4
Jan 28, 2003 02:43 PM
