Does anyone know what size halos to get for 2004 f150 headlights? I need the size for the main light bowl and for the turn signal bowl. I don't want to pay almost 200 for the Oracle kit. Any help would be appreciated.
Are you wanting to fit the halos within the lighting case(custom hacking) or replacement units with halos already included?
Im planning on retrofitting some projectors into my headlights, and want to fit the halos inside of the case. The biggest I've seen are only 120 mm halos. Thanks for the reply
The white circuit has more sizes than the black circuit ones. Each have many color options.
Note: the install pictures with the links, have some valuable tips of how to get housing apart, as you might have to measure to the right sizes.
Hope this helps your project!
Thanks! I think im going to just get strips of side emmiting leds and use those, the highest halo they sell is the 120 mm which is still to small! But I like the idea of using the leds and using them instead of a halo
