I used ranger hangers on my truck #2 build, I believe I have the years listed with the pictures in the build thread.
Springs have different center points and lengths, so not every spring will work for every application.
I am using Dakota springs and hangers on my truck #1 build and S10 springs with ranger hangers on my truck #2 build, lots of pics in the build threads.
Here is a link to a site with the info for many springs, makes it easy to figure out the differences in size, eye style, and load capacity.
I also used 90 Dodge D-50 (Dakota) springs and hangers on my 49 F-1. IMHO, they are better than Explorer because they come from a pickup and you don't lose load carrying capacity. They are also pretty close to the same length as the original springs. They were not hard to adapt to the Ford frame...
I just did a little research on the Exp and Ranger springs (I didnt want anythng but Ford parts on my truck)
I did brand new ranger springs, shackles, front and rear spring mounts, axle/ubolt plates,and u bolts for fairly cheap (considering everything was new)
Springs $65 each plus shipping was $180 (junk yard wanted $75 each for used)
shackels 20 each
front hangers 55 pair
rear hangers 20 each
axle plates 40 shipped.
I will need to fab up some lower shock mounts after I install the axle so i didnt get the plates with the shock mounts on them.
Everything I bought was brand new/reproduced parts, so no rust or junky beat up worn out parts and it was actually cheaper than going to the scrap yard plus i didnt have to leave my house.
Here is my thread, there is some useful info on the bottom of the last page
Seriously, your info helped a ton. I cant imagine ordering/installing stock replacement springs and bushings/pins, for the cost of swapping the exp/ranger components its a no-brainer unless you are retaining a stock truck
Explorer springs were rated higher than the 1/4 ton Ranger springs. By swapping in the Explorer springs into a Ranger, you get about a 1.5-2" lift, and they fit right in. So essentially they are the same, only thicker. AS new, the Explorer springs are a lot more expensive.
