Hey All;
Can anyone tell me if you can use 2 inch blocks on the front of my 78 F-250 (leaf springs) to gain a little space and if so, is there anything anyone would recommend?
Thanks.
Hey Cas1, I'm not the most familiar with those series of trucks, but in a little research it looks like they use a leaf to lift the front... I think adding a block would achieve the same thing, though I would be inclined to add ladder bars for stability, similar to what is done if using a large lift block on the rear of the truck. I'm sure someone with more knowledge than I will chime in.
Welcome to the chapter if you're a local member...
I'm fairly certain it is illegal to use blocks on the front of a leaf sprung truck, not only that it's also dangerous. Unless this is a strictly an off road vehicle, I highly advise not to use lift blocks in the front of your truck.
