Hp/torque for stock '99 psd
Old 07-19-2003, 10:28 PM
f350xlt460's Avatar
f350xlt460
f350xlt460 is offline
Im getting a 1999 F350 crew cab dually 4x4 7.3psd 6 spd on monday and am wondering what the stock hp/torque numbers are and at what rpm's. As for buying gagues, what is the order of importance and what gagues are used most. Is a programer recomended for mild increases in hp/torque?
Old 07-20-2003, 06:56 AM
powerstroker250's Avatar
powerstroker250
powerstroker250 is offline
Stock 235hp and 500ft/lbs of torque. Most important gauges are EGT and trans temp if you have an automatic. Boost gauges are fun to watch.
Old 07-20-2003, 07:25 AM
f350xlt460's Avatar
f350xlt460
might sound like a stupid question, but whats the difference between pyro and egt, if there is a difference?
Old 07-20-2003, 07:47 AM
f350xlt460's Avatar
f350xlt460
well, i just figured out that there isnt a dirrerence
Anyway, the truck im getting, the used truck dealer says is already programed a little bit. How do i find out? Ive heard that if you buy a programer that it only works on one truck, ie, it downloads the stock program and replaces it with a modified program. Then, the only thing you can do is upload the stock program back on your truck or change the existing program. Is that ture?
Old 07-20-2003, 08:48 AM
Calli's Avatar
Calli
Calli is offline
F-350. That is true for the Hypertech Power Programmer 111. It should be included with truck as it cannot be used in any other if it is loaded in yours. I recently remover the above from mine and installed Banks Stinger Plus. CA
Old 07-20-2003, 08:51 AM
Calli's Avatar
Calli
Calli is offline
F-350. That is true for the Hypertech Power Programmer 111. It should be included with truck as it cannot be used in any other if it is loaded in yours. I recently removed the above from mine and installed Banks Stinger Plus. CA
Old 07-20-2003, 09:57 PM
Fitzydog's Avatar
Fitzydog
Fitzydog is offline
Guys the Superchips programmer 1706? is proven to be the best for the 7.3 don't buy any other programmer or CHIP!! Good Luck
