Tranny fluid shot out of the dipstick
Old Oct 13, 2014 | 02:47 PM
74F100LGM's Avatar
74F100LGM
1974 F100, 302, stock engine and auto tranny.
Drove the truck for a few miles (literally 2 or 3 miles). When I returned I pulled out the tranny dip stick (engine off) to check the level. When I did, fluid shot out of the dipstick tube and all over the engine bay and manifolds (which smoked, but didn't ignite).
The truck seems to shift OK (upshift, downshift all feel fine). But clearly, something's wrong.
Any common problem areas that would cause this?
Old Oct 13, 2014 | 08:53 PM
fuzzybob's Avatar
fuzzybob
Should be a breather above the dip stick check to make sure it's open. Good luck with it.
Old Oct 14, 2014 | 08:34 AM
sirrealism's Avatar
sirrealism
Fuzzy bob is right on. There is a breather on the tranny that is not doing its job. Do you know if you have a c4 or c6? Breather is in different places for each. Also with it cold how is your fluid level? If its very high the breather cant do its job.
Old Oct 14, 2014 | 08:36 AM
74F100LGM's Avatar
74F100LGM
C4. I won't be near the truck for another two weeks, but I'll check it out when I get there! Where am I looking? And is there a procedure to clean it? Just a hose?
I had an issue recently with the speedo cable filling up with tranny fluid. I wonder if the pressure build-up cause that, as well.
Old Oct 14, 2014 | 08:58 AM
redroad's Avatar
redroad
Have a look here
ah1988
Mar 18, 2011 11:43 PM
eigenvector
1983 - 2012 Ranger & B-Series
Jan 13, 2010 10:02 AM
Tyson0317
Jul 12, 2008 10:53 AM
whitesdford
Oct 9, 2007 09:35 PM
4x4cowboy
May 20, 2002 10:54 PM
