Hood Help! !
Old Oct 12, 2014 | 07:28 PM
GaRedneck91's Avatar
GaRedneck91
Hood Help! !
Bad photo but it's late
I will post more pictures tomorrow, but in the mean time can anyone explain to me how to get my good to sit down in the rear. The bolts that hold the hood to the hinges are boogered up as in twistin em does no justice. How can I get my hood sitting right so I can throw some paint on her. Any advice is appreciated and again sorry for the bad picture but will for sure update during day light.
Old Oct 12, 2014 | 07:32 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I bet your hood hinges are worn out and not pulling it down tight? Maybe try to adjust the hinges lower? Or you will have to do the ol the push down on the back edges one its closed.....
Old Oct 12, 2014 | 07:59 PM
HIO Silver's Avatar
HIO Silver
If the hood hinge bolts don't tighten anymore, that means the nuts up inside the inner fender are spinning in their cage because at some point they were over-tightened.
Fixing it requires drilling out the spot welds, hammering the cages back into shape, and then welding them back on. Ask me how I know.
Old Oct 12, 2014 | 08:02 PM
GaRedneck91
Old Oct 12, 2014 | 08:07 PM
GaRedneck91
That sounds about right HIO. I wish I was more mechanically inclined. Is this difficult to do? What do I need? Would this make it not sit correctly?
Old Oct 12, 2014 | 08:18 PM
HIO Silver's Avatar
HIO Silver
I re-read your post.. is it the hinge-to-hood bolts that don't tighten or the hinge-to-inner fender? Or both?
The hinge-to-inner fender has some adjustability. It looks like the hood hinge's back side needs to go down and the front hood latch raised up.
It's gonna be a compromise at best. Tolerances were as loose as a goose with these work trucks. But I would look to get the back side of the hood even with the cowl.. that's more important. It'll probably end up with a large (horizontal) gap between the fender and the hood.
Patience is required.
Old Oct 12, 2014 | 08:49 PM
GaRedneck91
Alright HIO after goin out there and wrenching on the bolts they all seem to be plenty tight: hinges to hood/ Hinges to Inner fender. Before the bolts from hinges to hood were stripped I thought, mabe my cousin fixed em as he was the engine installer. But as of now they will not tighten up. So to fix I should raise the hood latch in the front and that will sit the back down? As the looks of it there's two bolts that hold the front latch on, do I loosen em and slide the latch up. Sorry about the confusion, just tryin to let you know the facts so you can help me correctly. Thanks bud
Old Oct 12, 2014 | 09:24 PM
HIO Silver's Avatar
HIO Silver
Like I said, it's gonna be a compromise. Work on the hood-to-cowl alignment first. The hood hinges will need to tilt - the back side coming down and the front part of the hinge generally staying in the same place. It's a balancing act... use the hood latch support to even up the horizontal fender-to-hood gap.
Old Oct 12, 2014 | 10:03 PM
GaRedneck91
10-4 I'll fool wwith it tomorrow and let you know how it comes along and what's it lookin like.
Old Oct 12, 2014 | 10:54 PM
NBC-Steve's Avatar
NBC-Steve
I'm doing the same thing and like HIO says it will require time and patients as its a royal PITA.
Old Oct 13, 2014 | 03:17 AM
Bud Mud's Avatar
Bud Mud
to get the back of the hood down. You may need a buddy to help, loosen the 2 most rear bolts of the 3 that hold the hinge to the inner fender,have someone push up on the front of the hood so the back of the hinge pivots down then tighten those 2 bolts and that will bring the back off the hood down. Close the hood SLOW to make sure it isnt hitting any where. Ive been doing auto body over 35yrs, ask if you have any more ?????
Old Oct 13, 2014 | 08:53 AM
bertha66's Avatar
bertha66
That is how I got the rear of my 76 to set down and it helped with how the latch worked!
Old Oct 13, 2014 | 10:01 AM
GaRedneck91
Bud mud that was the trick. That thing sittin down good now I sure appreciate it, learn somethin every day
Old Oct 13, 2014 | 10:06 AM
GaRedneck91
Sittin pretty now. There was a large gap before thanks bud
Old Oct 13, 2014 | 10:19 AM
Bud Mud's Avatar
Bud Mud
KOOL!!!!!!!!!! Looks good,glad i could help.
command37
May 30, 2017 03:12 PM
thepitshop
24
Sep 22, 2016 07:56 PM
gfburke
20
Apr 12, 2015 12:54 PM
mcali2
Aug 19, 2014 10:29 PM
Jeff55F100
Jul 18, 2012 11:21 AM
