1999 Ford ranger starts when put in gear
Old Feb 20, 2014 | 03:14 PM
CJB24's Avatar
CJB24
I have a 1999 ford ranger 2.5L. When I turn the key to the ON position, right before the ignition turn, everything comes on like it's supposed too. However, if i try to change into reverse, the truck will start without me even touching the key. Also, if I start it using the key and try to go into reverse, the starter engages and makes the all to familiar grinding sound. I am completely stumped. Any ideas?
Old Feb 20, 2014 | 06:25 PM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Sounds like the ignition switch, or its control/actuating rods are on the fritz & or its contacts are stuck in the start position???? Have you been having problems with the ignition switch lately????
Old Feb 20, 2014 | 06:39 PM
CJB24's Avatar
CJB24
Yes, the actual owner claims it started about 2 weeks ago. It started to happen on rare occasions and slowly progressed (this is what the guy claims). We've pulled the ignition switch out and it seems to be Alright. We've also swapped the actual ignition with one from an Econoline and it acted the same way.
Old Feb 20, 2014 | 08:46 PM
pawpaw's Avatar
pawpaw
Does this puppy have an auto tranny????
Old Feb 21, 2014 | 01:55 PM
smalltrucker's Avatar
smalltrucker
Just happened to look down in the electrical section and someone else has similar problem.
Dave
https://www.ford-trucks.com/forums/1...l#post14089817
brent1204
General Automotive Discussion
Feb 10, 2014 11:16 AM
traumadog29
Feb 1, 2007 09:47 PM
mosnarde
Oct 20, 2004 04:19 PM
rio3
Mar 22, 2004 09:23 PM
Southern_Son
Jun 12, 2001 10:33 PM
