1996 ranger ignition problem
Old Jan 26, 2007 | 10:01 PM
traumadog29's Avatar
traumadog29
I have a 1996 Ranger with a 2.3 L engine. Recently the ignition lock set has started turning all the way around and sometimes it takes several times to get the truck to start. When you try to crank it, it will turn like its suspose to and just click once. It may do this a couple of times until it finally cranks. I changed the ignition key set, but the problem persists. It seems like if you turn the key to just the right spot it starts. Is this a problem with the ignition switch inside the column? Any suggestions? Thanks, Keith
Old Jan 26, 2007 | 10:24 PM
RangerPilot's Avatar
RangerPilot
Yes...that's a very very worn out ignition switch. They're fairly pricey...but the install isn't too difficult.
Old Feb 1, 2007 | 09:47 PM
traumadog29
Thanks
Just wanted to thank you. My Ranger starts great with the new switch.
Thanks,
Keith
