Can't find battery drain
Old Jan 1, 2014 | 03:36 PM
ejanzen's Avatar
ejanzen
something is causing my battery to drain overnight. I put a circuit tester between the cable and battery terminal and it lights up when the truck is off.
I then pulled every fuse one at a time and the light on my circuit tester never went off.
should I remove all the fuses and then start putting them back in to see which circuit is causing the drain?
are there fuses anywhere else in this truck (2003 Expedition) that I have missed besides the ones in the passenger footwell?
Old Jan 1, 2014 | 03:58 PM
r2millers's Avatar
r2millers
You should have the circuit board under the hood, next to the master cylinder.
Are you testing current draw specifically? If testing continuity or voltage, you wouldn't expect the light to go off.
Check to see if the mirror lights go off on the visors.
Do you have an after market alarm system added besides PATS?
New radio recently installed?
Power seat switches work properly?
If checking current draw, what kind of amperage draw do you see?
Old Jan 1, 2014 | 05:35 PM
alloro's Avatar
alloro
Pull the fuse for the rear wiper and see if the battery still drains overnight.
Old Jan 1, 2014 | 05:36 PM
pdqford's Avatar
pdqford
Don't forget the rear wiper draw if it can't park itself.
Old Jan 1, 2014 | 05:41 PM
alloro's Avatar
alloro
Too late, beat you by one minute!
ProStreetDriver
General Automotive Discussion
Oct 16, 2017 12:49 AM
colson327
Feb 27, 2014 01:03 PM
KentWilkens
Oct 5, 2011 02:33 PM
DRanchero
Electrical Systems/Wiring
23
Jul 18, 2006 09:56 PM
johnanderson
Jan 6, 2004 03:43 PM
