98 Expy left rear brake light
Old Jan 1, 2014 | 11:52 AM
bcompton35603's Avatar
bcompton35603
My left rear brake light does not come on when brakes are applied..Unless the right turn signal is on, then the brake light comes on. the upper brake midbar and right brakelight is fine. Left rear tail light works too. Have replaced bulb, does not fix.
Old Jan 1, 2014 | 02:39 PM
alloro's Avatar
alloro
Worn turn signal switch.
Old Jan 1, 2014 | 04:04 PM
r2millers's Avatar
r2millers
Does the left hand signal work? It's the same filament and would expect it to also not work. Check the contacts where the bulb is inserted for possible corrosion.
Ensure ground connection is good there too.
Old Jan 1, 2014 | 05:43 PM
alloro's Avatar
alloro
If it were a bulb connection then it wouldn't come on when the right turn signal is activated, which it does.
Old Jan 1, 2014 | 09:55 PM
bcompton35603
I determined it is in the turn signal, I can jiggle it and the brake light comes on
Old Jan 2, 2014 | 05:51 AM
alwaysfords41's Avatar
alwaysfords41
Technically I think Alloro determined it was in the switch, you just confirmed it.
Old Jan 5, 2014 | 01:06 PM
bcompton35603
I had figured it out before I had received a reply to my post, but thanks.
bburnette252
2009 - 2014 F150
Dec 7, 2018 12:06 PM
Tailbreaker
13
Jul 20, 2017 06:32 PM
tigertrucker
Feb 6, 2011 06:50 AM
seymour
Aug 6, 2002 09:27 PM
