blind spot mirror removal 02
Old Dec 25, 2013 | 08:20 PM
st8yd's Avatar
st8yd
Mine is cracked and I was given another unit but don't know how to remove them and don't want to brake it trying.
Thanks
Old Dec 25, 2013 | 09:13 PM
guitarpicr's Avatar
guitarpicr
All I can say is be very gentle with it - I cracked mine a few years back. I take a small pry bar with a 90* hook on the end. Work it in around the back of the mirror.There are 2 tabs about 2" from each end in the middle of the mirror ( you are talking about the little convex mirror on the bottom , right).Work the pry bar back & forth from one side to the other & it will eventually pop out. I would also wait until it is warmer out to do this as the cold make the plastic on the back more brittle, or it seems that way. I put a little vaseline on the tabs of the new mirror b4 re-installing same & use gentle even pressure with a towel or rag.
Leakypete
Feb 24, 2014 06:06 PM
Jbrown8988
Jan 2, 2011 12:13 AM
jbondi
1978 - 1996 Big Bronco
Sep 8, 2009 02:38 PM
flagator84
2004 - 2008 F150
Aug 12, 2004 10:32 AM
19felix69
Jul 6, 2003 07:02 PM
