97 Expy stuck in 4WD Low- help plz
Old Dec 13, 2013 | 11:20 AM
Splbuilder's Avatar
Splbuilder
Hello, new to the forum. I own a 97 4WD and it is stuck in 4WD low. I did not even move the switch to 4WD. Got up this morning and it is in 4Low. With the switch in any position, and no lights on the dash lit up, it stays in 4WL. Tried everything I could think of including trying to shift from Neutral with the brake on. Any help is appreciated as I cannot afford to send to a mechanic. Even if I could get it back to 2WD only that would be a great help. Thank you to anyone who helps, I greatly appreciate it.
Jeff
Cincinnati, OH
Old Dec 13, 2013 | 02:25 PM
alloro's Avatar
alloro
Check fuse #17 in the interior fuse box.
Old Dec 15, 2013 | 01:34 PM
Splbuilder's Avatar
Splbuilder
Fuse 17 is good. Fuse 6 for the GEM module is good. Looking for help.
I pulled the GEM module but now apparently no auto parts stores near me have even heard of this part. Just my luck.
Old Dec 15, 2013 | 01:37 PM
alloro's Avatar
alloro
It's a specialty part, you have to get one from the dealer, a rebuild shop, eBay, or a junkyard. Whichever route you go, make sure all of the numbers on the label match.
Also, if you get under the truck and remove the shift motor from the back of the transfer case, you can manually move the cam out of 4WDL.
Old Dec 15, 2013 | 01:41 PM
Splbuilder's Avatar
Splbuilder
Thank you for the help alloro. Is there a tutorial on that by chance? I've never done that-
Old Dec 15, 2013 | 01:56 PM
alloro's Avatar
alloro
Here is a PDF showing how to remove the shift motor.
File Type: pdf
cotten616
13
Feb 16, 2021 08:35 PM
MRW530
1997 - 2003 F150
Sep 26, 2013 09:41 AM
jrdufford
Oct 14, 2008 09:08 PM
jnicho6
1997 - 2003 F150
Feb 14, 2008 12:44 AM
ironhorseinsp
May 23, 2004 06:06 PM
