Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F800 starting issue?
Old Nov 12, 2013 | 01:44 PM
Pete Kildow's Avatar
Pete Kildow
Ran the truck today, and did good. Met my wife to eat lunch in town. When I went to leave the truck would only click when turning the key? Head lights worked and wipers worked. So not the battery.
Shorted the starter out and fired it up, with the key on dash is dead, NO speed or tach or other gauges works. When you turn the key the tach will move just a bit. Any ideals what to look at or check on this? Does it have a fuze that could have blown?
Funny part is a guy pulled up trying to buy it with it not starting. And even crawled up under it and fired it off for me. And still wants it. But don't think he will offer what it would take to buy it. Think he is # 14 that has tried to buy the old truck within the last few months.
My wife is trying to get me to just sell and it buy something newer. and if it keeps having issues I may pass it along and just buy me a Volvo tractor and fix it to pull the camper with.
1987 Ford F800 7.8
Old Nov 12, 2013 | 06:38 PM
Maxium4x4's Avatar
Maxium4x4
I moved you from General Diesel to Large truck so we may get the guys in here for a better answer since it is more a wiring issue.
Hope I am right for Pete's sake....
Old Nov 12, 2013 | 09:21 PM
Pete Kildow
Thanks thought that was where I was posting it. But see I was way off. Again thanks
Pete
Old Nov 12, 2013 | 09:57 PM
nevrenufhp's Avatar
nevrenufhp
My first thought is a neutral safety switch, or clutch engage switch.
Old Nov 13, 2013 | 08:45 AM
Pete Kildow
Would one of those make the dash not have have power also? I thought of those but did not know if it would cut all power to the key and dash.
Pete
Old Nov 13, 2013 | 09:00 AM
Maxium4x4's Avatar
Maxium4x4
I would think if you have no power at all to the dash it would be a central main fuse. Maybe someone around here has a wiring diagram.
Old Nov 13, 2013 | 10:23 AM
nevrenufhp's Avatar
nevrenufhp
Oh... I read it wrong. I was thinking it all had power but no start
Old Nov 13, 2013 | 05:53 PM
Jeff Pattee's Avatar
Jeff Pattee
Burned fusible link at the starter relay? Jump the starter relay and the truck starts.
Old Nov 13, 2013 | 06:21 PM
Pete Kildow
Will try to find that and see. Not sure where the Link may be, but will sure be looking for it.
May so a little more work on the truck. Then put it up for sale. New Truck is looking better. But the new price is not LOL
Pete
Old Nov 14, 2013 | 03:04 PM
gandrimp's Avatar
gandrimp
Do these truck have a cab solenoid?
Old Nov 15, 2013 | 05:15 PM
Jeff Pattee
Yes, it mounted on the drivers side fire wall below the master cylinder and next to the W/S washer reservoir.
Old Nov 15, 2013 | 11:27 PM
Pete Kildow
Don't have a master Cylinder? And theres nothing to do with the starter there. Now there is one on the pass side frame next to the right steer tire. This truck has the 7.8 Diesel and air brakes.
Thinking its the bendix on the starter. I have it clicking again but still no start. Not sure what I did to get the power back to the dash and key?
Pete
Old Nov 17, 2013 | 06:51 AM
Jeff Pattee
ok, my truck has a Cummins 5.9 and uses juice brakes with Lucas Gerling parking brake system. I'll look for your set up. have you checked the wiring at the starter?
Old Nov 17, 2013 | 09:02 AM
Pete Kildow
Jeff when this rain stops I plan on checking the wires at the starter. But not sure how they would stop the dash gauges from having power? I have somehow got it to click when I hit the switch now. So that tells me its something to do with a wire at the Starter or the starter its self.
Pete
Old Nov 19, 2013 | 03:14 PM
Pete Kildow
Wires at the starter is tight, solenoid was clicking after hunting what it could be. So thought throw a new solenoid on it. Now it will not even click. Also checked the power on both side of the fusible link had power both sides. Blower fan for the AC and heat will not even blow. This is sure odd?
Bet its the same as it would be on a F-150 through F-350 as the cab is the same as these are. So will ask again in that section and ask it as one of the above trucks.
