Uneven Rear/Air Suspension
Old Jun 21, 2003 | 02:54 PM
OnePunch's Avatar
OnePunch
Question Uneven Rear/Air Suspension
I recently had a strange rattle in the left rear of my 01 EB Exped (24K miles). Ford worked on the truck for a week - end result bad shock! They replaced the left shock and control arm.
Fixed the rattling noise but, my truck now rides at about 34" on the left (driver's) side and 33" on the right (passenger) side. I took the truck back and they said the air suspension was within Ford's acceptable levels. The problem is it is NOT within MY acceptable level!!! The truck look like I have an uneven load!!
What can I do???? Any ideas????
Old Jun 22, 2003 | 09:20 AM
tsdrallyer's Avatar
tsdrallyer
The shocks have nothing to do with the air suspension or the level of the truck. Somebody screwed up the settngs for the airbags while they worked on your truck. Ask them again nicely to fix it, and if they say no, ask for the number of the regional Ford representative. Call him/her and explain it was level going in, not coming out. It's the dealer's problem now.
Old Jun 22, 2003 | 10:52 AM
BigMattXXL's Avatar
BigMattXXL
OnePunch-
Welcome to FTE Sorry to hear about your problem - this is absolutely unnacceptable. Ford has a computer that you plug in and set the yaw (or pitch? side to side) and takes about 20 minutes to adjust. This is provided that each wheel can be adjusted independently - I know the Navigators can be adjusted like this.
"Acceptable level"....bah.....
For the record - it's not going to be perfectly level - it just doesn't happen. Mine dips a bit to the left, but you can't really tell without using a level. It might also just be the difference between the one broken in shock and the brand new one - both carry the same amount of air, but one might have lost its stiffness. Either way, the answer you got was really shabby. I'd go back and speak with the service manager, and if that doesn't work, just keep heading up.
Oh, and be civil and polite - always. A little politeness goes a long way.
Keep us posted!
XXL
Old Jun 26, 2003 | 09:05 PM
OnePunch's Avatar
OnePunch
Thanks for the replies!!! I went back to the Ford dealership, "nicely" expressed my frustration, and they agreed to look into the problem!! That was Monday!!
I called today to check on the status. The Service manager stated that they are still working and are determined to fix the problem.
I am waiting with MUCH hope!!! I will keep you posted
Old Jun 26, 2003 | 11:00 PM
tsdrallyer's Avatar
tsdrallyer
You didn't say if you had just rear load levelers or 4 corner, but what it's worth, after 112K miles of heavy duty use on and off road, my '97 with four corner air still sits perfectly level.
Old Jun 30, 2003 | 10:41 PM
OnePunch's Avatar
OnePunch
Thumbs up Uneven Rear/Air Suspension
Finally!!! I must give the dealership credit!!! They checked the motor, flushed the lines and replaced the rear air bags!!! Guess what. . . . . . the damn thing is LEVEL!!!
Old Jul 1, 2003 | 05:40 AM
BigMattXXL's Avatar
BigMattXXL
Excellent - see? a little courtesy goes a long way!
XXL
Old Jul 2, 2003 | 08:08 PM
OnePunch's Avatar
OnePunch
True!! But it does help that the General Manager of the delearship is a GOOD friend of mine.
Honestly, I try not to abuse him!!!
Old Jul 3, 2003 | 08:52 AM
BigMattXXL's Avatar
BigMattXXL
Certainly doesn't hurt - I'm glad you got your situation sorted out!
XXL
Old Mar 19, 2005 | 05:03 PM
bigperk87's Avatar
bigperk87
how much weight can the levelers handle. (98 expedition eddie)
Rifboy
2009 - 2014 F150
May 9, 2014 07:48 PM
TrickyT150
2009 - 2014 F150
Jul 8, 2013 05:15 PM
FM20
Jan 12, 2012 09:33 PM
JRFallinJr
Jun 10, 2009 06:56 PM
AirTran
1997 - 2003 F150
Aug 26, 2004 05:50 PM
