Using '53 ignition switch in '50 F1?
Old Oct 6, 2013 | 12:54 PM
j_siegel's Avatar
j_siegel
Howdy all,
My 3-post generic ignition switch crapped out on me the other day and I wanted to go original. I bought a switch from eBay listed as an F1 switch, but it turns out it's an F100 switch.
It looks like it won't fit in the dash without cutting (grinding) which I'm obviously not going to do. Has anyone here used this particular switch in an F1? What did it take, and did it fit the original bezel? It's just a bit large to fit in so I could grind the switch, but I think the pot metal would crack.
The alternative is to use a generic 4-post and only use the three terminals, or maybe I buy a CG Ford Parts switch. Does anyone know if the cylinders interchange between 53 and 50? I paid $50 for the switch and the CG parts one doesn't come with a cylinder, so maybe I should hold on to it.
Thanks!
Old Oct 6, 2013 | 02:16 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Sacramento Vintage Ford shows a "new" item 1948-50 ign. switch housing part #7835-0 you can see if its what you need on there web site. "EDIT" the also carry the cylinders if needed. Good luck.
tjdad62
Dec 29, 2013 04:11 PM
Jolly Roger Joe
Aug 6, 2011 09:04 PM
propane32
Jul 29, 2005 05:34 PM
Woodsman_30350
Jul 14, 2004 08:25 PM
Dan_the_Ford_Man
Oct 27, 2002 04:30 PM
