50 and 51 same ignition switch?
Old Oct 27, 2002 | 05:36 AM
Dan_the_Ford_Man's Avatar
Dan_the_Ford_Man
My 50 F1 iginition switch was removed and the hole was enlarged for a latter model switch leaving a real mess. I've got a switch from a 51. Does anybody know if they're the same? I'll have to weld up the hole to make it fit and I only want to do this once.
Thanks,
Dan
Old Oct 27, 2002 | 10:19 AM
51dueller's Avatar
51dueller
[updated:LAST EDITED ON 27-Oct-02 AT 11:20 AM (EST)]The switchs are the same. I have a picture of my switch with several different keys in my gallery.
Nathan
I made a mistake the first time. Doh
Old Oct 27, 2002 | 10:50 AM
Dan_the_Ford_Man
Nathan,
Great picture Thanks! Yep, that's just like the one I have. Now if I could just get the cylinder out....
Old Oct 27, 2002 | 01:38 PM
barry's Avatar
barry
If you have the key, put it in cyl and turn to accessories position. There's a hole in it that you can see a pin in. push the pin down and then pull the cyl and key out. Sometimes the pin doesn't push down very well. Do not force it down. Squirt some penetrating oil in to lube it.
Old Oct 27, 2002 | 04:30 PM
51dueller's Avatar
51dueller
