4x4 99 ranger front wheel bearings, how hard?
Old Aug 31, 2013 | 02:06 PM
mfp4073's Avatar
mfp4073
They are a squeaking and drivin me crazy. how hard are they to do, do they need a press or can they be done at home?
Old Aug 31, 2013 | 03:09 PM
03 Maz B23's Avatar
03 Maz B23
Here's link on replacing them. If you have a NAPA with a machine shop you could remove the rotors get them checked to see if salvageable and need turned and buy new bearings/seals and have them reinstall and pack them with grease so all you would need to do is reinstall.
| Repair Guides | 4-wheel Drive Front Suspension | Front Wheel Bearings | AutoZone.com
Old Aug 31, 2013 | 04:15 PM
mfp4073's Avatar
mfp4073
I may be wrong about this, but i thought my disks slide right off once the wheel is off?
Old Aug 31, 2013 | 05:04 PM
03 Maz B23's Avatar
03 Maz B23
From what I read it appears they do so you don't need to deal with the rotors. Am used to the 2wd setup and no such luck with them.
Old Aug 31, 2013 | 05:09 PM
Rockledge's Avatar
Rockledge
Are you sure it's the wheel bearings that are squeaking?
The '98-'00 4x4 Ranger front hub bearings are not serviceable. You will need to replace the hub/bearing assembly as a whole.
Check out: TRS Magazine - 98-00 Ranger Hub/Bearing Assembly Replacement
IIRC you have also been having issues with the front hubs failing to engage. So you might also consider replacing the original PVH hubs with the AVM manual lockers while you are at it.
Old Aug 31, 2013 | 09:06 PM
mfp4073's Avatar
mfp4073
My 4x4 has never worked. So who knows! I believe the transfer case motor is bad, but also the hoses in the hubs are rotted and the lines corroded!
Old Aug 31, 2013 | 09:50 PM
Rockledge's Avatar
Rockledge
Is the front driveshaft engaging when you switch to 4WD? If the front shaft spins when the truck is in motion and 4WD is selected, then the TC is fine.
All the more reason to abandon the existing vacuum hubs (or modify them to be engaged all the time).
Old Sep 1, 2013 | 09:36 AM
mfp4073's Avatar
mfp4073
I actually have the front drive shaft out right now! But yeah, I dont think its engaging. Been meaning to get around to fixing it, but since I have never really had the need its been on the way way way back burner.
tdl0
1997 - 2003 F150
Nov 2, 2016 12:48 AM
bigbubba87
19
Oct 25, 2011 10:29 PM
frank5
Nov 12, 2006 03:35 AM
ckstrawser
13
Mar 24, 2003 05:28 PM
