front wheel squeeking
Old Nov 5, 2006 | 05:20 AM
frank5's Avatar
frank5
Cool front wheel squeeking
99 ranger 4x4 I have an intermittent squeeking in my left frony wheel, changed brakes and rotors with no success,please help
Old Nov 5, 2006 | 08:18 AM
sfcwoodret's Avatar
sfcwoodret
Check the brake pad calipers.
Old Nov 5, 2006 | 09:09 AM
frank5's Avatar
frank5
have done that and they seem to be working just fine
Old Nov 5, 2006 | 07:54 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Replace the wheel bearing
Old Nov 7, 2006 | 12:11 AM
msully005's Avatar
msully005
i have the same sort of problem in my 93 i have replaced the brakes, rotors, calipers, wheel bearings, and greased everything a few times it will squeek most of the time at low speeds and when turning. i think it is coming from the drivers side. any ideas
Old Nov 7, 2006 | 03:47 AM
frank5's Avatar
frank5
Wish i could help you.mine is also on the drivers side
Old Nov 11, 2006 | 07:29 PM
GaryF629's Avatar
GaryF629
Since you have a 4X4, did you check your hubs? If you have the auto hubs, and have not cleaned and lube them lately, I would disassemble them, clean them with a good parts cleaner, and grease them. I would do this every couple of years, old grease and dirt is what causes these hubs to fail.
When I had this problem (After doing all the normal cures...brake, bearings and suspension.) I ended up replacing all the rubber bushings. Made a big improvement!
Old Nov 11, 2006 | 08:37 PM
soundwave's Avatar
soundwave
I had the same problem in my 1999 4X4 Ranger Sport. Same wheel and everything. I even took it to the dealer to see if they could pinpoint what it was and they said they didnt see anything amiss. A week after the dealer trip (and a month of a squealing tire at this point ) it just stopped. Why it stopped and why it started is still beyond me but, please, let us know!
Old Nov 12, 2006 | 03:35 AM
frank5's Avatar
frank5
wheel squeel
thanks guys for the info, it hasn't made the noise now for over a week
