will my 2007 f250 ford diesal motor fit into my 2006 f350 diesal truck?
Old Aug 14, 2013 | 06:05 PM
wapachu's Avatar
wapachu
hey new here know idea if this is right place was just wondering if this is possible?
Old Aug 14, 2013 | 06:10 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Just so we're all on the same page from the start.... both came with the 6.0L and the 5R110W automatic transmission or ZF6 manual transmission, in trucks sold in North America correct?
If yes, assuming the transmission is the same, it'll should drop in. If you're moving it from a manual to an auto truck or vice versa, you can move the long block assembly and accessories, but not all the electronic modules. IIRC the PCM is different between auto and manual trucks.
_Me2_'s Avatar
_Me2_
Yes, it will fit and it is possible.
Old Aug 14, 2013 | 06:20 PM
wapachu's Avatar
wapachu
thank you guys alot my f350 recently died on me mechanic said engine is gone. So im going to do this
Old Aug 14, 2013 | 06:23 PM
texastech_diesel
Token Redneck
How did it die? Maybe we can help you figure out what's salvageable on the old engine.
raptor131's Avatar
raptor131
Why did it die? We need details, a death in the 6.0 is a tragic event for all of us
Old Aug 14, 2013 | 06:44 PM
wapachu's Avatar
wapachu
Low oil pressure came up on the moniter thing. It was shooting up lots out lots of black smoke on every startup eventually it would clear and run good then It would drive for a little bit then shut off and not work till the next day then eventually it just died and took it to the mech cause i couldnt bare to let her go but he just said nothing he could do engine fried. Bad deal cause i recently replaced the high pressure oil pump like 3 months prior.
Old Aug 14, 2013 | 08:26 PM
bismic's Avatar
bismic
How well does your mechanic know 6.0L's?
Are you willing to invest a hundred dollars or so to do some investigating on your 06?
Quite frankly, there isn't enough information to actually condemn it yet (IMO anyway).
It is not common for low oil pressure to fry an engine since "low" high pressure oil pressure will prevent starting - usually before damage is done.
Old Aug 14, 2013 | 09:00 PM
99ExpyProblems's Avatar
99ExpyProblems
Listen to these guys, many of them know their stuff. It sounds like your mechanic is looking for a big payday!
Old Aug 14, 2013 | 09:04 PM
04badford's Avatar
04badford
That's a great point mark, I would assume FICM , batteries,ICP and connections LPOP if not enough oil pressure, and 100 bucks to a real 6.0l Mechanic is money well spent
Old Aug 14, 2013 | 09:45 PM
wapachu's Avatar
wapachu
ya im willing to spend the money truck has lots of setimental value. but there are really 0 good mechanics in the area thats why im here looking for help on where to start and what to look for
Old Aug 14, 2013 | 09:48 PM
bismic's Avatar
bismic
You should consider buying a scangaugeII and doing some tests yourself then. We can help ........... There is a recent post on scangaugeII for a little over $100 at Advance Auto w/ a promo code.
Old Aug 14, 2013 | 09:51 PM
bismic's Avatar
bismic
Where in Canada are you located?
04badford's Avatar
04badford
you get a lot of good help here ,that's for sure, have you gone thru the Chapters section in your area? on the top of this page is the forums button click and scroll down to chapter find the area that's closest to yall.whats your gauge reading ? FICM,IPR ,ICP,ICPV?
Old Aug 17, 2013 | 08:44 AM
bismic's Avatar
bismic
Any updates?
