S-belt
Old Aug 10, 2013 | 07:41 AM
C. Lee Colbert's Avatar
C. Lee Colbert
S-belt
the mechanic tells me the serpentine belt needs to be replaced....is this something I should attempt, or leave it to the pro's?
Old Aug 10, 2013 | 10:55 AM
03 Maz B23's Avatar
03 Maz B23
pretty easy (at least with 4cyl). you use a 3/8 ( if i remember right) ratchet and extension which fits into square hole on tensioner to release tension and remove /install belt. a little easier if you have a helper to guide new belt in place while you release tension on tensioner when reinstalling.
Old Aug 10, 2013 | 11:04 AM
JWC 3's Avatar
JWC 3
If you can change your oil , you can change this belt . Easy job .
Old Aug 10, 2013 | 03:10 PM
C. Lee Colbert
Mine has a V6...
Old Aug 10, 2013 | 03:26 PM
KhanTyranitar's Avatar
KhanTyranitar
Still easy. If you don't learn how to tackle easy maintenance jobs like this, you will forever be a slave to mechanics.
Old Aug 10, 2013 | 03:32 PM
03 Maz B23's Avatar
03 Maz B23
Here is link with general directions how to replace it.
| Repair Guides | Engine Mechanical Components | Accessory Drive Belts | AutoZone.com
Old Aug 10, 2013 | 10:23 PM
Old93junk's Avatar
Old93junk
If you can manipulate a door ****, you can replace this belt.
1 tool, and a routing diagram is under the hood.
Old Aug 11, 2013 | 09:23 AM
pawpaw's Avatar
pawpaw
It'll take more time to get things together & the hood open, than to change the belt, so its a good thing to do in beginning to learn to turn your own wrenches, save $$$$ while doing it & feel great when you've successfully completed the task.
Here are some more thoughts you may find helpful in installing the new belt.
Ford Truck Enthusiasts Forums - View Single Post - serpentine/driv belt wear
Before leaving the store with the belt, look on the belt to make sure the one in the package is the right part number one for your engine (that the belt hasn't been swapped into the wrong package)!!!!
Make sure the pulleys are clean, smooth, & dry, so you don't contaminate the new belt. Then after installation, check the tensioner molded in range marks, to make sure the belt tension is within range. If it isn't, the belt is either too long. or too short, maybe the wrong part number!!!!
I store my old belt under seat, just in case the new one breaks, I have a backup that can get me home.
Let us know how the replacement goes.
Old Aug 11, 2013 | 05:27 PM
C. Lee Colbert
S-belt
Thanks guys...I will give it a shot & keep you all informed on the results!
Old Aug 11, 2013 | 07:18 PM
C. Lee Colbert
I must ask a silly question though...does the serpentine belt take the place of a timing belt/chain?
Old Aug 11, 2013 | 07:47 PM
JWC 3's Avatar
JWC 3
No . It only drives the fan , wp , alt. ect .
Old Aug 11, 2013 | 08:40 PM
C. Lee Colbert
OK, So there is a timing belt inside the engine then?
Old Aug 11, 2013 | 08:50 PM
JWC 3's Avatar
JWC 3
Timing chain and gears , not a timing belt on your v6
Old Aug 11, 2013 | 09:01 PM
C. Lee Colbert
OH, OK...Shows how little I know! thanks for all the info!
Michaeltharris
Sep 7, 2009 09:55 PM
Lil Blue
Oct 12, 2008 10:32 AM
pat2724
1997 - 2003 F150
Apr 17, 2007 07:57 PM
df150
Dec 23, 2003 08:03 PM
BTHiii
1997 - 2003 F150
Jul 24, 2003 12:42 AM
