Swapping a late 90's 351W into a 54
Old Jul 31, 2013 | 06:04 AM
Oxfordrider's Avatar
Oxfordrider
I am wondering if anyone has installed a late 90's 351W from a F150 in a 54. I am currently running a tired 1974 351W with a C6 and a 9" rear end with 3:00 gears. I would like to keep the C6 but am open for suggestions. I am looking for input on level of difficulty and hidden problems. Thanks for the input.
Old Jul 31, 2013 | 07:06 AM
sdetweil's Avatar
sdetweil
it should bolt right up. the only overdrive tranny choice is the AOD. get it built right for the higher power of the truck engine.
is this vintage still carbed? I took out and sold a late 90s 351w stroker from my 56.
Sam
Old Jul 31, 2013 | 07:22 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
There are lots of crate motors available that would be an almost direct bolt in swap. Surf Roush, JEGS, Summit and Ford Motorsport. There would only be slight differences like the oil dipstick goes into the side of the pan instead of the front cover/water pump area.
My 56 has a crate motor, C-6 and 9" with 3.50 gear. What part of MN are you located in?
Old Jul 31, 2013 | 08:13 AM
yamagrant's Avatar
yamagrant
That engine is EFI. If you can get the trans with the engine, take the computer and complete wiring harness. I will be running a 5L Aod from an 88 Lincoln in my 56. It just makes the truck serviceable on the road. I'm a licenced auto tech by trade, and find the newer brand of tech's are not familiar with the carb systems. Good luck.
Old Jul 31, 2013 | 10:27 AM
52 Merc's Avatar
52 Merc
I kinda thought we've already been over this, and determined the 351 for 351 would be a direct swap? I realize the thread took a bit of a left turn with all kinds of crazy advice, but the basics were there...
https://www.ford-trucks.com/forums/1...selection.html
Old Jul 31, 2013 | 05:02 PM
Oxfordrider
To answer some questions. I am in Woodbury, MN. My question was more in the line of what you did to make the computerized fuel system work.
Frank
Oct 31, 2022 09:49 PM
happymech
Aug 8, 2014 02:42 PM
CaptainFarina
Oct 12, 2009 12:35 PM
NealLittle
Apr 19, 2004 11:59 PM
CNdev
Oct 16, 1999 12:14 AM
