E40D swap to 5 speed manual
Old Jul 12, 2013 | 07:27 PM
tbugher62's Avatar
tbugher62
Can someone give me a list of parts that I will need to swap a E40D too a 5 speed manual,I know I need these but what else ?
5 speed tranny
pilot bearing
clutch plate
flywheel
steering colum cover
foot pedal assembly
clutch plate bearing
Old Jul 12, 2013 | 08:04 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Let's see if I don't forget something while I type this.. lol
ZF5 trans
Flywheel
clutch
pressure plate
pilot bearing
throwout bearing
clutch release fork
slave cylinder
clutch master cylinder
clutch hydraulics line
shifter and shifter boot
either manual trans floor pan or cut the correct hole out of your auto floor pan
manual trans PCM and/or chip tuned for manual trans
manual trans wiring harness for reverse lights
manual trans crossmember
build driveshaft(s) to correct length or get driveshafts from correct wheelbase manual trans truck
steering column cover
P R N D 2 1 instrument cluster cover plate
clutch/brake pedal assembly
Old Jul 12, 2013 | 10:10 PM
fordpride's Avatar
fordpride
Make sure your zf5 is from a 7.3l diesel
The gasser one will not work
Old Jul 13, 2013 | 07:46 AM
tshrager's Avatar
tshrager
Make sure you get the correct pedal assembly. Pre 93 won't work. Don't ask me how I know.
Travis, you don't have to run a manual PCM or even have a chip tuned for a manual. As long as the wiring is correct it will operate like its supposed to. I'm running both that are still autos.
Old Jul 17, 2013 | 08:02 PM
tbugher62's Avatar
tbugher62
Does anyone have any of these parts that they would be will to sell me for my swap,I have a 96 PSD 7.3, 2wd.
Old Jul 17, 2013 | 08:37 PM
BuckHammer's Avatar
BuckHammer
I'm pretty sure my pedals are out of a pre-'93 truck. They work fine. What about the pedals was not compatible?
To the OP, you can find all of the information about pretty much everything about the swap by reading through my pathetic struggle to get it done on my truck, lol. I'll get a link to that monster thread here in a second. Stand by...
Edit: Here you go. Click on the link to my thread here: Transmission Impossible
Old Jul 17, 2013 | 08:56 PM
tshrager's Avatar
tshrager
Nope. Completely different style. They will not bolt up. I have the set that didn't work in my shop.
Old Jul 17, 2013 | 09:13 PM
strokin'_tatsch
And it doesn't romp on start up?? Does it accelerate when you let off the clutch at idle like a manual trans truck???
Old Jul 17, 2013 | 09:34 PM
tshrager's Avatar
tshrager
The only time it romps is if I start and immediately let out clutch and add fuel. Only then and it's not often at all. Not sure I follow on the second question. I can let out the clutch with no throttle and it'll take off.
Old Jul 17, 2013 | 09:37 PM
BuckHammer's Avatar
BuckHammer
Hmm... My pedals may be out of a newer truck, then. There's really no way for me to know for sure without asking Ian (plgebbia), if he remembers.
Old Jul 17, 2013 | 09:45 PM
ReBilld's Avatar
ReBilld
Pre '92 won't work. '92-'97 are the correct pedal assemblies. '91 and back have a cast aluminum pedal box and won't bolt up in our trucks.
Old Jul 18, 2013 | 04:53 AM
tshrager's Avatar
tshrager
Well there you have it. Stand corrected again. My apologies Joseph.
Old Jul 18, 2013 | 06:16 AM
El Camino Man's Avatar
El Camino Man
And of course the pre-92 pedals are a dime a dozen... They kinda wrap around the steering column while a post-92 is just a flat plate.
Not to thread jack but is it possible to swap bellhousings on these ZF5s or is it all a single cast piece
Old Jul 18, 2013 | 06:50 AM
DIYMechanic's Avatar
DIYMechanic
It's all one piece. The transmission just needs to be from a diesel. Even the ZF5 used on the IDI's would work, it just has a different bolt pattern than the gas engines used.
Old Jul 18, 2013 | 06:52 AM
El Camino Man
That's what I figured... But its good news to hear an IDI will work too. That means you can get one from 80-97, minus the pedals lol
F-250 restorer
Apr 5, 2019 10:06 AM
gtmustang00
Jul 3, 2016 08:36 AM
tyman4640
Jan 18, 2016 01:08 AM
FossenRacing
Oct 10, 2013 01:12 PM
hster
Sep 1, 2004 12:34 AM
