On Excursion 6.0 4x4 has anyone switched from Goodyear Silent Armor to Michelin LTX-MS2 tires?
What I have experienced is the following:
Michelin Pros: Lower Rolling Resistance; Less drag when turning yielding shorter turning radius; better MPG by 1.0-1.5 MPG; better cornering; very quiet for LT 10 ply tires. Cons: They appear to give a harder ride on highway and side roads and I have felt a "looser" road feel on highway compared to the GSA's.
Have any of you experienced the same thing where the GSA's offer a softer (while definitely a little noisier) ride on the highway?
Thanks in advance for your input.
Jeff
I will be sticking with these.
they are hands down the best tire on the market. without a question
but...always one of those
they don't look the coolest, they are expensive, and they'll last for freakin' ever. This is my second set (different vehicles though).
I've also had the Silent Armour. Great tire. I loved it as well. And the price was very very reasonable. But it can't hold a candle to the Michelin. They do look nice however
After the 1st alignment (in degrees):
LF Camber .3; Caster 3.0; Toe .01
RF Camber -.2; Caster 3.2; Toe -.03
Total Toe -.03; SteerAhead .02
LR Camber .1; Toe .12
RR Camber -.03; Toe .16
Total Toe .27; Thrust Angle -.02
After the Realignment (in degrees):
LF Camber .3; Caster 3.0; Toe -.03
RF Camber -.2; Caster 3.2; Toe -.04
Total Toe -.07; Steer Ahead 0.00
LR Camber .1; Toe .13
RR Camber -.3; Toe .18
Total Toe .31; Thrust Angle -.03
Do you think those adjustments would tighten up the steering?
<table border="1" cellspacing="0" cellpadding="3"><caption>Alignment Specifications </caption><tbody><tr><th align="center" valign="bottom">Item </th><th align="center" valign="bottom">LH </th><th align="center" valign="bottom">RH </th><th align="center" valign="bottom">Total/ Split </th></tr><tr><td align="left" valign="top" colspan="4">4x2 </td></tr><tr><td align="left" valign="top">Camber </td><td align="center" valign="top">0.62° ± 1.0° </td><td align="center" valign="top">0.62° ± 1.0° </td><td align="center" valign="top">0° ± 1.0° </td></tr><tr><td align="left" valign="top">Caster </td><td align="center" valign="top">4.4° ± 1.4° </td><td align="center" valign="top">4.6° ± 1.4° </td><td align="center" valign="top">0.2° ± 0.75° </td></tr><tr><td align="left" valign="top">Toe @ curb ride height (positive value is toe-in, negative value is toe-out) </td><td align="center" valign="top">— </td><td align="center" valign="top">— </td><td align="center" valign="top">0.1° ± 0.25° </td></tr><tr><td align="left" valign="top" colspan="4">4x4 </td></tr><tr><td align="left" valign="top">Camber </td><td align="center" valign="top">0.25° ± 1.0° </td><td align="center" valign="top">0.25° ± 1.0° </td><td align="center" valign="top">0° ± 1.0° </td></tr><tr><td align="left" valign="top">Caster </td><td align="center" valign="top">3.63° ± 2.0° </td><td align="center" valign="top">4.0° ± 2.0° </td><td align="center" valign="top">-0.37° ± 0.55° </td></tr><tr><td align="left" valign="top">Toe @ curb ride height (positive value is toe-in, negative value is toe-out) </td><td align="center" valign="top">— </td><td align="center" valign="top">— </td><td align="center" valign="top">0.01° ± 0.25° </td></tr></tbody></table>
<table border="1" cellspacing="0" cellpadding="3"><caption>General Specifications </caption><tbody><tr><th align="center" valign="bottom">Item </th><th align="center" valign="bottom">Specification </th></tr><tr><td align="left" valign="top" colspan="2">Ride Height — 4x2 </td></tr><tr><td align="left" valign="top">Front — RH </td><td align="center" valign="top">108 mm (4.24 in) </td></tr><tr><td align="left" valign="top">Front — LH </td><td align="center" valign="top">114 mm (4.72 in) </td></tr><tr><td align="left" valign="top">Rear </td><td align="center" valign="top">156 mm (5.32 in) </td></tr><tr><td align="left" valign="top" colspan="2">Ride Height — 4x4 </td></tr><tr><td align="left" valign="top">Front </td><td align="center" valign="top">100 mm (4.44 in) </td></tr><tr><td align="left" valign="top">Rear </td><td align="center" valign="top">142 mm (4.92 in) </td></tr><tr><td align="left" valign="top" colspan="2">Ball Joint Deflection </td></tr><tr><td align="left" valign="top">Lower </td><td align="center" valign="top">0-1.0 mm (0-0.040 in) </td></tr><tr><td align="left" valign="top">Upper </td><td align="center" valign="top">0-0.6 mm (0-0.024 in) </td></tr><tr><td align="left" valign="top">Wheel bearing end play (4WD) — maximum radial </td><td align="center" valign="top">0.13 mm (0.005 in) </td></tr></tbody></table>
<table border="1" cellspacing="0" cellpadding="3"><caption>Torque Specifications </caption><tbody><tr><th align="center" valign="bottom">Description </th><th align="center" valign="bottom">Nm </th><th align="center" valign="bottom">lb-ft </th></tr><tr><td align="left" valign="top">Adjusting sleeve clamp nuts </td><td align="center" valign="top">55 </td><td align="center" valign="top">41 </td></tr><tr><td align="left" valign="top">Front spring U-bolt nut (4WD) </td><td align="center" valign="top">133 </td><td align="center" valign="top">99 </td></tr><tr><td align="left" valign="top">Rear spring U-bolt nut </td><td align="center" valign="top">200 </td><td align="center" valign="top">148 </td></tr><tr><td align="left" valign="top">Upper ball joint pinch bolt (4x2) </td><td align="center" valign="top">80 </td><td align="center" valign="top">60 </td></tr><tr><td align="left" valign="top">Upper ball joint nut (4x4) </td><td align="center" valign="top">94 </td><td align="center" valign="top">69 </td></tr><tr><td align="left" valign="top">Outer tie-rod castle nut </td><td align="center" valign="top">115 </td><td align="center" valign="top">85 </td></tr><tr><td align="left" valign="top">Lower ball joint nut (4x4) </td><td align="center" valign="top">204 </td><td align="center" valign="top">150
Alignment specs and recommendations - PowerStrokeNation : Ford Powerstroke Diesel Forum
and here: (This is the best alignment and suspension tutorial for the masses that I have ever seen)
http://mysite.verizon.net/res108eps/...ion-basics.pdf
front & 55 psi rear as was and is recommended by Ford for the Excursion 4x4. And they are obviously brand new, no wear so that cannot be the issue.
The alignment must have been off with the Goodyears as there was mild cupping on the tires after 45000 miles. And it could be that after the alignments what I am experiencing is just the difference in footprint, straight tread vs. aggressive tread?????
As I stated, there are many positives with the Michelins, the truck just "feels different" compared to the road feel I experienced with the Goodyears, the only tires on the truck since I have owned it!
No change in rake or lift from factory specs, original springs, etc.
So, based upon these charts, do I need to have them install caster shims to increase positive caster? And is my minimal toe-out incorrect as it should be 0? Or, are all my readings acceptable as they are within the accepted ranges? As you can tell I am a novice when it comes to knowledge of alignment!
Thanks for your help.
Jeff
I had some on my Excursion before I lifted it and it always got no less than 18 mpg with them on. I was driving into a bar on the lake and they had a little mud in their driveway, I started to drive through it thinking I'd be ok, but then tires started to spin. Two months later, the Ex got lifted and I put some BFG All-terrains on and just happened to end up at that same bar again, it walked right through the mud as if it wasn't there.
My advice:
If your truck spends most of it's time on-road and on the freeway, get the michelins.
If your truck occasionally goes off road and sees mud from time to time, get the Goodyear Silent Armor tires. They're a good combination of off-road grip and on-road manners while yielding good fuel economy.
or off road I have been in.
Is it possible that since they are filled with nitrogen, that the 1.5 psi difference was that noticeable?
