Need to Replace Spark Plugs, Recommendations?
Old Jun 25, 2013 | 10:25 AM
2SONS's Avatar
2SONS
I will be replacing all 10 of my spark plus on Saturday morning, when the engine is cold. Please let me know if you have any tips or warnings that will help make the project as hassle free as possible. Also, what brand of spark plug should I purchase? Thanks in advance.
Old Jun 25, 2013 | 10:31 AM
mgraveman's Avatar
mgraveman
Tip 1: Make sure insurance is current on the car.
Tip 2: Devise an alibi.
Tip 3: The minute anything goes wrong - Gasoline, Match - you know the drill.
Alternately, just change the plugs at the local boat ramp. If you take very long at all you'll have lots of help to just push it in!
Seriously, mine went fine. Make sure you have a couple 3" extensions for the ratchet. I didn't need a U Joint piece, but there wasn't a lot of room left over for the wrong extension. I used motorcraft plugs.
Old Jun 25, 2013 | 11:26 AM
EXv10's Avatar
EXv10
Use Autolite plugs (same thing), torque to 14 pounds, change the boots too, and do it all at one time so you don't screw it up and end up with a spit out plug.
Old Jun 25, 2013 | 01:23 PM
GermanMike's Avatar
GermanMike
I use LSG Brisk Plugs.
The engine runs way smoother at idle and over all RPMs.
But the best thing is that I could really see an increased milage.
I really can recommened those plugs
LSG Brisk Halo B-GR15YC-1. * * *
Old Jun 25, 2013 | 06:44 PM
2SONS's Avatar
2SONS
Mrgraveman - Thank you for the 3 step process, I really like the boat ramp suggestion as well. The only problem is all the ramps close to me are closed because the water level is too low from the drought in central tx. Therefore I will have to follow your 1st three suggestions.
Brent - Thanks for giving me the torque setting. I was already planning on purchasing a torque wrench for this project. I always like a good excuse to buy more tools.
I will purchase the autolite or Motorcraft Plugs. I doubt that spark plugs could make any difference in MPG especially for a beast that only gets 11 mpg on average.
Old Jun 25, 2013 | 06:50 PM
EXv10's Avatar
EXv10
I don't torque mine but I have put tons of plugs in..............not bragging, just sayin'.
Old Jun 25, 2013 | 08:27 PM
Bently_Coop's Avatar
Bently_Coop
Motorcraft Plugs, dielectric grease for the boot, antisieze for the plug threads. Take your time. If you have compressed air blow out the holes before removing plugs. Good luck and report back how it all went.
Old Jun 25, 2013 | 08:57 PM
EXv10's Avatar
EXv10
You only need a tiny bit of grease on the end of the spring to keep it from corroding, any more than that will attract dirt and grime. I use heavy grease around the tops of the boots to keep the water out and it has worked very well.
RadioControlGuy85
Jan 20, 2015 03:43 PM
Jaime74656
13
Sep 17, 2011 05:21 AM
jowilker
Mar 25, 2008 06:02 AM
pcguy760
Mar 27, 2007 05:45 PM
Frank Lang
May 19, 2004 11:03 PM
