56 Ford F-100/250 Master Brake Cylinder
Old Apr 25, 2013 | 08:42 AM
Outlaw56's Avatar
Outlaw56
I have examined both master cylinders for the 56 F-100 and F-250. The F-250 will not swap out with the F-100 because the bolt patters on the 250 are further apart. Both cylinders appear to take the same rebuild kit. I checked in the 56 Ford Manual and the diagram does not show where a flat round rubber washer goes in the kit. the washer is rubber, 3/16" thick, 1 1/4" in diameter and the hole in the center is 5/8" in diameter. The Ford Manual shows the kits internal parts from left to right....valve, spring, cup (rubber), piston, stop plate (metal retaining washer) and snap ring. There are no diagrams with the rebuild kit. Does anyone have an idea where this washer is installed?
Old Apr 26, 2013 | 07:20 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Is it for the fill plug?
Old Apr 26, 2013 | 07:58 AM
dmptrkr's Avatar
dmptrkr
It is the first part to go back in. Here are a couple of old threads about the extra rubber washer
https://www.ford-trucks.com/forums/7...ant-place.html
https://www.ford-trucks.com/forums/1...r-rebuild.html
Old Apr 26, 2013 | 09:02 AM
Outlaw56's Avatar
Outlaw56
Thanks Craig. If I get what is being said in those articles, the washer is the first to go back in. It also mentions the possibility of this being an "extra part" for "P" series which I assume is parcel delivery vans. It sounds like the kits may have extra parts for multiple applications and the washer in question could be an extra part. But then a majority of the posts talk about the washer being the first part to be installed in the cylinder. I do know the master cylinder on my F-250 is longer than the cylinder on my F-100. I also know the washer in question came out of the master cylinder off my F-250. I wonder if the washer may have something to do with the different lengths of the two cylinders and the travel of the pistion? Thanks again for pointing me to that thread.
hooler1
26
Jun 18, 2015 10:11 PM
Pappys53
Aug 20, 2011 04:29 PM
abe
13
Jul 12, 2009 06:51 PM
flatheadjohn
Jan 7, 2009 06:40 PM
Jul 14, 2001 06:50 PM
