need help with master cylinder
Here is my status in my master cylinder rebuild on my '54 F-100.
I have honed The cylinder. I think I got the rough spots smoothed out. I know when you take something apart you should remember the order you took them out. But I had the shop manual diagram and the spring pushed the stuff out when I took it apart.
Question: the shop manual these parts in this order: the spring and valve, cup, piston, stop plate, snap ring and the boot. The rebuild kit has all those pieces but it also has a thin spring washer and a thick rubber washer or grommet. These two pieces also came out of my master cylinder. Where do these 2 pieces fit in?
The question is: What other master cylinders does the overhaul kit you bought fit besides 1954 F100's?
The master cylinder is the same 1953/56 F100 (B3C2140A), but if you bought a universal overhaul kit, it may have parts that not only fit this master, but extra parts for other's like F2's, F3's, etc.
I've run into this before on the 1960's stuff.
Here is a drawing of the Master cylinder you should be working on. I hope it helps:
One other thing that came to mind last night is that I recall having this discussion about 9 months ago with another member. I believe that the drawings (including the one I provided) are a little misleading in that the "Valve Assembly" #2178, is actually two or three pieces, not just one. And I think that is where your extra parts came from (and the new extra parts go).
I found it and here is the link...too bad the pictures didn't survive. I'll try to find them again and if I do I can repost it for you.
https://www.ford-trucks.com/forums/7...t-place-2.html
You didn't see these extra parts when you dis-assembled the master cylinder, and now you are wondering where the extra parts from the kit go.
Julie, I studied the old thread and it looks like that guy had the same question
about those 2 parts. I looked at that thread quickly and I think it will help me.
This story reminds me of my Panel Trucks Carb. Took it apart for rebuild, let it sit for a year, then got back to it only to realize I forgot what went where and how. I put it back together, but I still to this day have the funny feeling that something is not correct. I don't have a running engine to test it out on either(except my newly rebuilt engine).
I take it from the "rebuild kit", you can't just buy new master cylinders, correct?
1953/56 F100 Master Cylinder / 1948/56 F1/F100 Master Cyl. Overhaul Kit
B3C2140A .. Master Cylinder / Obsolete / Fits: 1953/56 F100.
ANTIQUE AUTO SUPPLY in Arlington TX has THREE = 817-275-2381.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
AOA2004A .. Master Cylinder Overhaul Kit / Obsolete / Fits: 1948/56 F1/F100.
MILLER OBSOLETE PARTS in Binghamton NY has FOUR = 800-546-7278.
BOB ALLEN FORD in Overland Park KS has FOUR = 800-676-0675.
CAVEAT EMPTOR: Bob Allen is HIGH BUCK!
Try different auto parts dealers. Prices vary.
Here's what Rockauto shows for '54 with 6 cyl.:
DORMAN Part # M14019 {First Stop #5461320, B3C-2140-A}
w/Manual Brakes; Bore = 1-1/16" $61.79
DORMAN Part # M14021 {First Stop #5461385, B3TZ-2140-A}
w/Manual Brakes; Bore = 1-1/4"; 3/4 Ton
w/Manual Brakes; Bore = 1-1/4"; 1 Ton
$81.79
RAYBESTOS Part # MC14019 {Professional Grade Bore Size=1 1/16"} $83.79
$81.79
Update: I got the master cylinder together and put on the truck and hooked up the lines. I tried to bleed it and very little fluid came out. A friend with a vacuum pump tried to bleed them and couldn't. We removed the brake lines at the master cylinder and pumped the brakes and no fluid came out.
I took the master cyl. off and made sure the 3 outlets were open. I took the valve off and pushed on the cyl as if pumping the brake and just a little bit of fluid trickled out. So the problem was not clogged up outlets.
So I took the cyl apart again and will try another position for the 2 phantom parts. I put the thin brass washer between 2173 (cup) and 2169 (valve). On my old thin brass washer I could see marks were the the little holes from the valve were. So I am sure that is correct. I put the thick rubber washer between 2169 (valve) and 2188 (stop plate) thinking it served as a cushion for the returning parts after the brake pedal was released. Someone on that other thread said the rubber washer went in first. What do you think?
Was this my problem? the valve was not positioned correctly to permit fluid get into the cyl so it can be pushed out to the outlets???
I will try again Sat. AM and hopefully you guys and gals can give me some advise...
thanks!!
thanks!!
I got the master cylinder rebuilt. Put the thick rubber washer in first, bench tested it and it squirted fluid out the outlets real good. Put it on the truck and when I pumped the brake it got firmer. Bled each wheel and it works fine.... So far so good, hope it continues to work fine.
A friend said I should get a later model master cylinder that has 2 reservoirs. What year Ford master cylinder would fit under the floor? How much work would be involved for that change? And would I then be skipping down the Darkside path???
69 ford f100
02-09-2017 01:24 PM
pezsox
09-07-2016 03:04 PM
brhine_99
08-22-2016 10:25 AM
seagiant
03-08-2016 03:50 PM
