64-66 bumper
Old Apr 21, 2013 | 07:21 PM
664x4drvr's Avatar
664x4drvr
64-66 bumper
LMC lists a 64-66 chrome bumper. Anyone bought one ? says it isn't a 67-72.
Old Apr 21, 2013 | 08:35 PM
1966Jacked4x4's Avatar
1966Jacked4x4
I was checking them out also. The price and even the shipping seem to good to be true. On my last trip to the boneyard I seen he had a mint bumper that he had taken off one of the trucks and had stuck it in the bed which had an old camper on it. 50 dollars and what felt like a 1 mile hike back and it was mine.
Old Apr 21, 2013 | 09:00 PM
Jetcopterpilot's Avatar
Jetcopterpilot
Are you looking for a front or a rear bumper? If you need a front Bumper, you cannot beat Rock auto for price! As I understand And i am sure that NumbersDummy will chime in... the bolt pattern is the same on the 64-66 as it is on the later, but the difference is the curve of the bumper. I know this is true on the front bumpers.. the 67-72 will bolt right on a 64-66 but they are not arced they look the same but are straight from end to end.. so they don't quite match the front end contour.... Now I don;t know if that is the case for the rear... But it is something to take into consideration.... ND will clarify this, as i am sure I have some of it screwed up... I have an original 64 front bumper, and the new repop, which is straight, instead of arced only a ford truck guy would notice the difference the older one arc's about 1 1/2" - 2" inches, the new one has about 1/2 of arc..
1964 FORD F-250 Bumper
Old Apr 21, 2013 | 09:09 PM
664x4drvr's Avatar
664x4drvr
Yeah, Front . 64-66 only. Do not want a 67 up. I have a white one , was thinking of hauling it to elizabethton tn. to have it chromed on my way to f 100 sup nats. its bent slightly am afraid they wont get it right.
Old Apr 21, 2013 | 09:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4TZ-17757-C Painted & C4TZ-17757-D Chrome .. Front Bumpers / Painted obsolete, chrome reproduced.
1964/77 F100/350 except 1973/77 Ranger XLT's with horizontal bumper pads.
The part numbers are the same, but 1967/77's have different shaped bumper ends than 1964/66's.
C4TZ-17906-A Painted & C4TZ-17906-B Chrome .. Styleside Contoured Rear Bumpers / Painted obsolete, chrome reproduced.
1964/66 F100/250 2WD / 1966 F100 4WD / 1967/72 F100/350 / 1973/77 F250 4WD (High Boys) / 1973/79 F350's on the 140" wheelbase.
Old Apr 21, 2013 | 11:27 PM
jpbecker's Avatar
jpbecker
What is the difference between the 64/66 and the 61/63 front bumper? Just the mounting holes? Can the brackets be swapped to make it work or is there more to it?
Old Apr 22, 2013 | 12:12 AM
Jetcopterpilot
I don't know about the 61-63 but the 64 does bolt directly on to the front of the frame, there are no Brackets, At least that is how my 64 is!
Old Apr 22, 2013 | 07:55 AM
NumberDummy
1961/63 bumpers mount with 3 bolts per side in a triangular shaped pattern.
1964/77 bumpers mount with 2 bolts per side.
Old Apr 22, 2013 | 01:58 PM
Jetcopterpilot
Thanks Bill I knew there was another difference that I was missing!
Old Apr 22, 2013 | 06:54 PM
ddavidv's Avatar
ddavidv
Post
Tri-City Plating? They did mine, front one had a small bend in it too and they straightened it out perfect. Over twice the price but worth it, IMO. Repro bumpers are thinner, prep is poor and the chrome shows the less than stellar prep work. You get what you pay for.
Old Apr 23, 2013 | 06:52 AM
664x4drvr's Avatar
664x4drvr
I picked up a bumper at parts swap, Best I found out it is a 61-63. it has the three holes BUT is too short for my 66 .about 2in? on each side.
Old Apr 23, 2013 | 09:47 AM
daveengelson's Avatar
daveengelson
Appears from Bill's post there are a number of donor years to select from? Salvaged a front bumper of heavy gage material. A knucklehead clipped it pulling into parking space, purchased a replacement online and it was crap. Fortunately keep the bent bumper and ended up taking it to a local platng shop that specialized in straightening and re-chroming bumpers and it cost the knucklehead $200.
CamoF-250
Nov 26, 2018 06:59 AM
lgwilson
15
Feb 23, 2011 07:28 PM
wagonerkl
36
Jan 14, 2009 03:57 AM
78 explorer
Sep 3, 2008 07:12 AM
nomadic
Paint & Bodywork
Jan 29, 2008 10:37 AM
